Proper Condenser Fan Motor Replacement - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-12-2013, 03:50 PM   #16
Rewards Points: 77
Originally Posted by algjst View Post
Thank you sir! That's what I suspected, but I wanted to confirm it with an expert.
Experts we are not...but thank you for the compliment!
Stay cool in the summer and warm in the winter! Airstar.
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
Old 02-15-2013, 11:22 AM   #17
Hello again ... I thought I was finished asking questions, but here are a couple more.
An online vendor recommended an Emerson 7232 motor to replace the one in my unit. They said they couldn't get the MOT02642, but the specs on the Emerson 7232 match.
Any thoughts on the Emerson 7232? I saw that the mount on the Emerson motor was hub ring. I have a belly band mount in my unit. Would that be a problem?
Thanks again!!
Gary
algjst is offline   Reply With Quote
Old 02-15-2013, 11:56 AM   #18
Rewards Points: 77
We have confirmed that the MOT02642 are readily available at the factory - I'd suggest another vendor or secure one locally thru a Trane or American Standard Dealer? This OEM Motor is pricey. The resilient mounts are often standard on blower wheel , at a 48 frame most likely it can work with a belly band no problem. Make sure Amp Rating and SF - Service Factor are correct for your application with the MOT07232.
Old 02-16-2013, 08:00 AM   #19
I was able to find the MOT02642 motor from several vendors online. Even the vendor who told me it was not available found the motor after I told them I wasn't interested in the Emerson motor. Ironically, they ended up having the lowest price once they located the motor.
Outside condenser fan motor stops tatums4 HVAC 21 10-12-2011 08:17 PM
Condenser fan airflow direction?? nicksab HVAC 8 09-20-2011 09:24 PM
reduced cooling after condenser fan failure technic HVAC 9 08-07-2011 01:02 AM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 07:05 AM
Condenser unit not working? kcombs816 HVAC 9 07-05-2011 08:24 AM
