Proper CFM For A Dedicated Room - HVAC - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 10:47 PM   #1
Rewards Points: 150
Proper CFM for a dedicated room
As far as CFM's required. I understand that it's the cf. of the room times a minimum of 4 divided by 60 for the formula.
My room is 1206 cf. so according to the formula;
air circulated 4x per hour = 80 CFM
air circulated 6x per hour = 120 CFM
All of the equipment will be in the room and it will hold up to 6 people. Does heat produced hold any relevance when calculating proper CFM for an enclosed HT? How many CFM's should I shoot for?
At the very most, the room fully occupied will be producing 9170 btu's or heat.
Was considering this fan...too powerful? not powerful enough?
http://www2.panasonic.com/webapp/wcs...1&displayTab=O
Thank you.
Mijotter is offline   Reply With Quote
Old 04-13-2013, 01:32 AM   #2
An old Tradesmen
Rewards Points: 6,570
Its not the cubic foot of a room that determines how much air it needs. Its the heat produced in the room, how much heat the room gains, and the temp of the air that is being put into the room that determines CFM.
So you have 6470 BTUs from equipment, and 2700 BTUs from people. What about heat gain through the walls.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (04-13-2013)
Old 04-14-2013, 02:40 PM   #3
Rewards Points: 150
Not much heat gain through the walls at all as it's 100% insulated and the room is surrounded by exterior foundation walls and an unfinished portion of the basement. What would be the proper CFM and amount of air exchanges per hour require for this room.
Old 04-14-2013, 03:03 PM   #4
An old Tradesmen
From an A/C with a 20 degree cooler air temp enteing the room then the room is, about 300 CFM.
Old 04-14-2013, 03:09 PM   #5
Rewards Points: 150
Oh wow. Is that even possible with a 6" flex duct? Would it cause a "wooshing" noise at the vent?
Old 04-14-2013, 03:56 PM   #6
An old Tradesmen
It would take 4-6" flex ducts.
You have a 3/4 ton cooling load.
Old 04-14-2013, 04:12 PM   #7
Rewards Points: 150
I'm sorry did you mean four 6" flex ducts? I plan on building 2 dead vents(1 for supply and 1 for return) for the room so as to isolate the theater vents from the rest of the duct work for sound isolation purposes. Here is what it looks like:
Old 04-14-2013, 04:18 PM   #8
An old Tradesmen
Yes, four 6".
Or you can use a 1-10".
You would be better off just installing a ductless mini split. using ir for another room to cool the theater room, won't get you humidity control. So it won't be comfortable.
Old 04-14-2013, 04:31 PM   #9
Rewards Points: 150
Well I've been told to use the fan I linked in the return and supply dead vent and just have them both run at the same time the whole time i'm down there. Would that work or still no. The adjacent room in the basement has 3 supplies and 1 return already from the main furnace and a dehumidifier.
What do you mean IR from another room? Infrared signal?
Old 04-14-2013, 06:14 PM   #10
An old Tradesmen
LOL. "ir" was suppose to be "air".
The person who told you to just use that fan set up. How well does it work in their theater room.
Tags
air , btu , cfm , fan , vent
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 03:49 PM
Choosing a Color Scheme For Your Room Micheal11 Interior Decorating 0 08-10-2012 11:03 PM
Assessing value of layout changes mbianco General DIY Discussions 6 07-22-2012 12:48 AM
Vapor Barrier on elevated 4 season room Indyc0lt Insulation 3 09-15-2011 02:41 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
