Propane Water Heater Shuts Off - HVAC - DIY Chatroom Home Improvement Forum
Old 03-19-2009, 11:33 AM   #1
Propane water heater shuts off
I have a propane water heater that keeps shutting off, when I check the unit it is in a stand by mode. If I turn the blower switch off then on about 6 times it will finally start working. The flame seems to be going out and when it does light the flame looks to be very erratic. Is this some kind of burner issue or flame rod issue? My tank is also at 50 percent, so I am not out of propane... Thanks!!!
jcross is offline   Reply With Quote
Old 03-19-2009, 09:21 PM   #2
HVAC / Plumbing
is this a 90 % water heater vented with pvc ?? If so check for obstruction in the vent.
kenmac is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
Water Heater tsmith Plumbing 10 12-01-2008 07:24 PM
Water heater "leak"? TCinKC Plumbing 1 09-25-2008 01:01 PM
