Propane Tank To Fireplace Connection Question - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2014, 08:06 PM   #1
Rewards Points: 6
Propane tank to fireplace connection question
Hey all! I am hoping I can pick the brains of some of you experience gas guys and gals. I am connecting a Kingsman LP gas fireplace to a 100lb propane tank. The gas guy I was working with did the connection from the outside to the fireplace, so I am all set with that, but I did not have the tank when he was available to do the work. Now I am burdened with the task of connecting the gas line to the tank. I bought an MEC two stage regulator (high to low, 11"wc) and a single 90 degree brass fitting (1/2" flared to 3/8"). The connection to my tank with the regulator went smoothly. The regulator input end had a flared tip which connected to the output valve on the tank easily enough. The output of the regulator was just a simple 3/8" female connector, so the 90 degree 3/8" to 1/2" fitting worked well between the regulator and the end of the gas line. I plan on using yellow thread tape on the ends that aren't flared and have include a couple of pictures for you to review. If anything looks out of whack, or dangerous, by all means please let me know! I appreciate the help in advance!
Thanks!
Keith Andrews
Propane tank to fireplace connection question-imag2758.jpg   Propane tank to fireplace connection question-imag2757.jpg   Propane tank to fireplace connection question-imag2754.jpg
keith_andrews is offline   Reply With Quote
Old 11-21-2014, 07:34 AM   #2
Rewards Points: 13,774
Around here where required to use a flex line from the valve inside to the log set.
There's no location in your profile so anyone's going to have to guess at what other codes may apply.
In CA I'd guess that tank would need to be attached to the house for example.
Old 11-21-2014, 09:28 AM   #3
Rewards Points: 6
Thanks for your reply. I personally would've appreciated a flex line to my fireplace because I had to move it's position a little after the installer did the work so the solid line made it a little more difficult to do so. Other than that, does the regulator connection at the tank look legit? I'm in Maine by the way, so yes, I understand there are going to be some different regulations in each state.
Propane Tank to Hot Water Heater AJPJAK Plumbing 9 05-29-2014 07:00 AM
well pressure switch NJ Lady Plumbing 32 12-16-2013 03:48 PM
Question about small propane tank and pressure darthsmozers HVAC 32 12-13-2013 06:07 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
propane tank switch. waverly guy HVAC 13 09-14-2009 08:25 AM
