#1 |
Propane Tank buried vs. above ground
Hi-
Contractor suggests that we bury the propane tank as oppose to putting it above ground. Not sure why to do this other than being hidden from view. And, everyone I see in the area (hilltown in western Massachusetts) has it above ground. Looking for the pros/cons of having the tank buried vs. above ground. Certainly doesn't seem very eco-friendly. Thanks! |
#2 |
#1 HAWKEYE FAN
a lot of people bury their lp tanks these days. the thing is you need to ask your supplier. around here the lp supplier will rent you a 500 gallon tank for about $5.00 a month, however if you want a tank buried you have to buy it and they cost about $3000.00
| The Following User Says Thank You to hardwareman For This Useful Post: | CheriAlli (11-15-2010) |
#3 |
HVAC / Plumbing
Not allowed to bury here anymore.All propane tanks now have to be above ground
| The Following User Says Thank You to kenmac For This Useful Post: | CheriAlli (11-15-2010) |
#4 | |
An old Tradesmen
Propane Tank buried vs. above groundQuote:
Here, the tank rent is anywhere from 50 cents to over a dollar a gallon added to your LP bill. |
| The Following User Says Thank You to beenthere For This Useful Post: | CheriAlli (11-15-2010) |
#5 |
Thanks to all for the very useful comments! I will be sure to check with the supplier before making this important decision.
#6 |
Wire Chewer
I'd keep it above ground, at least you can paint/maintain it easily. You can also make something creative like make it look like a big Advil pill or something. :D
#7 |
Propane Tank buried vs. above ground |
| The Following User Says Thank You to operagost For This Useful Post: | CheriAlli (11-15-2010) |
#8 |
good idea!
#9 |
Hvac Pro
I wonder what happens if there is a leak in it or the pipe from it? Propane is heavier than air and will fill up underground voids and can be dangerous and explode. I would always want it above ground for service and safety. Probably illegal to deface/paint it. Hide it behind a lattice enclosure.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to yuri For This Useful Post: | CheriAlli (11-15-2010) |
#10 |
An old Tradesmen
Don't know if I would paint the name Strickland Propane on it.
A delivery guy may not get the joke. And refuse to fill it. |
#11 |
good point!
#12 | |
HVAC / Plumbing
I must be missing something... strickland propane??? |
| The Following User Says Thank You to kenmac For This Useful Post: | CheriAlli (11-16-2010) |
#13 | |
#1 HAWKEYE FAN
I had a brand new tank delivered a few weeks ago from a supplier, for a 500 gallon tank the yearly rent is $48.00. Around here you can find used tanks pretty easily and buy them for $400.00 to $500.00, then shop around for the best price when its time to refill. |
| The Following User Says Thank You to hardwareman For This Useful Post: | CheriAlli (11-16-2010) |
#14 | |
| The Following User Says Thank You to operagost For This Useful Post: | CheriAlli (11-16-2010) |
#15 | |
| The Following User Says Thank You to Starglow For This Useful Post: | CheriAlli (11-16-2010) |
| Display Modes | |
| Propane Mower Conversion | homerb | Green Home Improvement | 18 | 09-16-2010 01:01 PM |
| Adding ground in old home | ChaosTheory | Electrical | 6 | 06-16-2010 05:02 PM |
| Propane Range hookup to 20lbs tank? | PaoloM | HVAC | 0 | 06-09-2010 11:47 AM |
| septic tank problems. | littles | Plumbing | 1 | 02-24-2010 10:30 PM |
| propane tank switch. | waverly guy | HVAC | 13 | 09-14-2009 09:25 AM |
