Propane Smell - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2006, 10:40 AM   #1
Propane Smell
Hello. I have a new Carrier 48GS. It uses propane instead of natural gas. When we turn on the heat we get a propane smell in the house. Outside there is a strong smell that comes from the vent of the unit. Is this normal for this type of unit...especially one that runs on propane? Thanks for all you help.
sjhandy1971 is offline   Reply With Quote
Old 12-26-2006, 10:55 AM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi sjhandy1971
When they installed your new dualpack, did they install the LP kit along with it?. It sounds like to me they forgot to convert it. I would reccomend having them come back and check it. The part number for your LP conversion kit is CPLPCONV006A00. They need to make sure that the manifold gas pressure is not above 3.5" water column also. THIS IS A LOW PRESSURE LP KIT.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 12-26-2006, 02:12 PM   #3
The manifold pressure for most all LP burrning apaliances is above 10 inches of water colum.And although It is not impossible to forget to convert a gas burning unit over to burn on propane (different orifaces and spring in gas control valve) I would like to think that only a brain dead technician would do something so stupid.
I tend to want to think that you simply have a leak and it is getting drawn into the home via the air supply ducting. Obviously as a safety concern the best advise any trained technician can give you at this point is simply to shut OFF the propane supply to the unit and call the company out as an emergency and have them locate and repair the reason for the smell.
Please stop back and let us know what was the cause as we always want to know if we helped and gave you correct information.
acefurnacefixer is offline   Reply With Quote
Old 01-05-2007, 09:48 PM   #4
Thank you Carrierman and Acefurnacefixer for your replies. I had a tech come out and check our unit and both of you were right. The problem was what Carrierman thought...no LP conversion kit. And Acefurnacefixer was right in that they were brain dead technicians. I had a different tech come and check for the LP kit because the original techs did such a horrible job. I will not ever let them back on my property again. Thanks again for your help.
Old 01-06-2007, 05:54 PM   #5
Rewards Points: 502
sjhandy1971
Thank you for stopping back in and letting us know your problem has been addressed. Believe it or not, I am sure I speak for all of us here. Its nice to see the problems get solved, and that no one gets hurt. The solution is what we are here to help you find.
Thank you
Rusty
Kitchen drain smell krtw Plumbing 6 03-07-2010 01:50 PM
Seal Cat Smell On Brick flyingzs Flooring 5 08-09-2007 02:20 PM
Installed bathroom sink, smell now HuskySkull Plumbing 1 07-20-2007 05:12 PM
Moldy smell...how to locate? TNeat General DIY Discussions 3 07-06-2007 09:54 PM
'Earthy' smell in house from crawl... HilleMary Building & Construction 5 08-30-2005 10:13 PM
