Old 09-17-2012, 02:37 PM   #1
Propane line to house - permit needed?
I want to start new propane service to an existing house. To replace electric water heater with point-of-use propane. Do I need a permit with the city before I dig trench and lay pipe or can I just go ahead and do it?
jackwashere is offline   Reply With Quote
Old 09-17-2012, 02:48 PM   #2
concretemasonry's Avatar
If you are running from a remote tank, your propane supplier may be able to give you some experienced advice for your location. If you use enough, you may get them to install and/or supply the tank. - It is not to likely since it is just for heating water, but you might learn something or even get lucky.
Dick
concretemasonry is offline   Reply With Quote
Old 09-17-2012, 06:13 PM   #3
An old Tradesmen
Weather you need a permit or not, is up to your local AHJ, call them and ask.
Old 09-17-2012, 08:49 PM   #4
Missouri Bound's Avatar
Are you buying the tank or is the supplier providing it? If the latter the supplier will take care of those details. Around here, the supplier does everything, including the trenching. But that would be the first place to ask your question.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
concretemasonry (09-17-2012)
Replacing rooftop deck - permit needed? esk8mw Building & Construction 5 01-27-2012 03:02 AM
Relocating House Main Supply Line Entry setzerr Plumbing 0 07-15-2011 07:44 PM
Tree house project plans needed. timrec Building & Construction 1 02-13-2011 09:38 PM
Just bought a 1946 house, redoing kitchen, what electrical fixes/upgrades needed? TomServo Electrical 18 09-21-2009 07:48 AM
