Propane Heater To Natural Gas - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2014, 11:59 AM   #1
Rewards Points: 31
Propane heater to natural gas
i bought online the mr heater model MHVFB20TB LP propane heater.i either ordered the wrong heater or they sent me the wrong one,since i have natural gas.it states clearly on the box that this can only be used with propane gas.can this heater be converted to be used with natural gas.i have included 2 pics,one showing the gas connection.thank you, paul
Propane heater to natural gas-mms_picture.jpg   Propane heater to natural gas-mms_picture-2-.jpg
pberm1962 is offline   Reply With Quote
Old 02-23-2014, 01:12 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
IT might but since it is their fault, have them replace it.
You would have to replace or convert the regulator and replace the burner orifices.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 02-23-2014, 01:42 PM   #3
Rewards Points: 31
thanks
thanks for the reply,,, i have to call the company monday and find out if i ardered it wrong or they sent me the wrong one. you are right it would not be worth converting it if i can just return it at their expense for the shipping
Old 02-23-2014, 01:47 PM   #4
An old Tradesmen
Rewards Points: 7,356
Send it back.
Old 02-23-2014, 04:24 PM   #5
Rewards Points: 582
picture of piping shows natural gas and propane.. so it most likely can be converted....but why do that...it new still in box...ship it back and get the right one tell them its there mistake....ben sr
Old 02-23-2014, 04:28 PM   #6
An old Tradesmen
It list both gas pressures. most likely because its cheaper to have one box printed with both pressures, then to have a separate box for each fuel.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (02-24-2014)
Old 02-24-2014, 06:30 AM   #7
Rewards Points: 582
sorry i did not read post completely ...you say you don't know if it was your mistake or theres....always be honest tell them just the way you explained it here ..it will all work out... even ..worst case it cost some added shipping...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
rjniles (02-24-2014)
Old 02-24-2014, 11:01 AM   #8
Rewards Points: 154
a lot of the heaters come shipped to be used for either. Read the instructions and see if there is a selector switch on the thing that will let you select NG. The last two wall heaters that I installed had this option.
Patrick Eubanks is offline   Reply With Quote
Old 02-24-2014, 11:09 AM   #9
Rewards Points: 154
I pulled up the owners manual and your out of luck. Propane only.
convert 125 btu reznor heater from natural gas to propane stewde HVAC 15 11-20-2013 03:42 PM
propane wall heater won't light help! jonni HVAC 8 11-07-2012 06:36 PM
Natural Gas House,,,,,how to have a Propane back up? gwillett Appliances 6 04-13-2012 10:35 PM
Natural Gas Heater and Lines Leroy1985 HVAC 14 11-11-2010 10:08 PM
Propane heater won't stay lit qoncept Tools 5 02-19-2010 08:19 AM
