Old 12-04-2007, 01:54 PM   #1
Question
propane heat
I am trying to find out what heating avenue I should use more. I have a propane whole house system and a propane fireplace. It seems like the fireplace keeps it warmer and if I turn my heat down to 60 degrees the house will stay warm all night from using the fireplace and turning it off before bed. What uses less propane? This is a 1200 sq ft home, 6 yrs old. and we are new owners. Thanks
sharpeidar is offline   Reply With Quote
Old 12-04-2007, 08:17 PM   #2
Thoroughbred Mopar Man
propane heat
Hi sharpeidar
That is kind of a trick question. If the fireplace is a vented one and the furnace you have is a 80% plus you are not really going to notice much difference either way. If your fireplace is a non vented and you are using a 80% plus, the fireplace will out perform your furnace as most are 99% efficient. If you have a 90% plus furnace and a non vented fireplace you will not notice much difference in performance as far as gas consumption. The newer houses are so well insulated they heat for pennies on the dollar. The most efficient way to go in any house is geothermal, but we will save that for another day. Hope this helps with your question.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
More On This Topic
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
The efficiency of a fireplace depends on several factors. Though the design is certainly important, it isn't the only thing to consider. Adding components and performing routine maintenance are critical to maximizing efficiency. No matter what type of... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Propane heating questions Badfish740 General Discussion 1 09-25-2007 08:46 PM
Convert from electric heat to oil/propane? Badfish740 HVAC 7 05-15-2007 12:17 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
