Propane Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 10:08 AM   #1
Propane Furnace
I have a Trane XB90 propane furnace.When i turn it on it sits and clicks but will not light.I replaced the ignitor,(it was broke I had found anyway) That didn't work.I notice the draft inducer motor humms but doesn't kick on,then gets hot and kicks off Could it be that motor needs replaced?Thanks Mike
jacobman5 is offline   Reply With Quote
Old 11-03-2011, 01:38 PM   #2
REP
The inducer comes on and makes a pressure switch which allows the gas valve to open the pilot valve.
REP is offline   Reply With Quote
Old 11-03-2011, 01:40 PM   #3
So it should be the inducer thats bad?
Old 11-03-2011, 06:36 PM   #4
HVAC Tech/ Browns Fan
You need a new draft motor. You also need check out the warranty on that
Tator1076 is offline   Reply With Quote
Old 11-03-2011, 09:39 PM   #5
30 year tech
hvac122's Avatar
Can you turn the inducer by hand? Could be a bird or something else is stuck in the fan.
hvac122 is offline   Reply With Quote
Old 11-03-2011, 09:54 PM   #6
A bird.....
Im glad I live in heat pump land....
Master of Cold is offline   Reply With Quote
Old 11-04-2011, 12:59 AM   #7
REP
Originally Posted by Master of Cold View Post
A bird.....
Years ago my brother bought an older cottage with a natural gas furnace.When I got there to clean it I found three starlings and 1 and 1/2 squrils dead in the flue and draft hood area.The other half must have burnt up,at least I hope thats what happened LOL.
Old 11-04-2011, 08:07 AM   #8
Thanks for the suggestions I will be checking them out tonight.The warranty ran out in january of course Funny that you mentioned the birds,I found a couple dead down there last spring(unfinished basement)
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
'93 Comfortmaker RPJ propane furnace lifespan? Dawsonhope HVAC 5 11-21-2008 05:47 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
