Programmable Thermostat With A Wireless Sensor? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 03:27 PM   #1
Programmable thermostat with a wireless sensor?
Hi there,
I live in a Chicago two flat home. I live on the 1st floor and rent out the 2nd floor unit to tenants.
There is only one furnace & AC unit for the entire building. The furnace is located in the basement and the ducts service both floors.
The programmable thermostat is
located and controlled in my 1st floor unit.
My tenants have complained about both high and low temperatures in Summer and Winter.
They have a non connected thermometer in their unit which appears to show the temperatures vary 5-6 degrees respectivelyfrom my unit.
Is there a programmable thermostat with a wireless sensor that I could place in their unit in order to monitor & adjust according to the temperature on the 2nd floor?
Thanks,
Stephen
scraig is offline   Reply With Quote
Old 02-24-2010, 06:02 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
Never heard of anything like that. If you want to just monitor their temp remotely check this out. Wireless weather station. One of my customers got one of these and his neighbor can monitor his house temp while he is on winter vacation. Can transmit 30 metres or 100 ft for my Southern metric challenged friends.
http://www.canadiantire.ca/AST/browse/5/SportsRec/Camping/CampingAccessories/PRD~0761178P/Wireless%252BWeather%252BStation.jsp
I am sure something similar must be available in your area.
Old 02-24-2010, 06:47 PM   #3
Houston204's Avatar
Rewards Points: 556
http://customer.honeywell.com/techli...e_SD_6inch.jpg
http://customer.honeywell.com/techli...69-2057EFS.pdf
Honeywell has a nice option.
Houston204 is offline   Reply With Quote
Old 02-24-2010, 06:53 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 396
All the NICE new toys that are coming out. Lennox has a whole batch of " i Comfort " stats /communication system coming out soon. Mucho dollaros though.
Old 02-24-2010, 10:22 PM   #5
Rewards Points: 502
Venstar makes wireless tstats too (they are often rebranded as Carrier)
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Remote sensor for line voltage thermostat? hbridge HVAC 7 07-06-2012 03:42 PM
Programmable Thermostat Suggestions... monkeystomach HVAC 5 02-05-2010 04:07 PM
Thermostat w/ wireless Remote Sensor Davidb6 HVAC 2 02-10-2009 07:45 PM
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 10:02 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
