Old 02-04-2010, 08:22 PM   #1
Programmable Thermostat Suggestions...
Hi all! I have been lurking for a month or so and now I need your input. I just purchased my first house and one of the first things I plan on doing is replacing the old thermostat with a programmable one.
I have a York Diamond 80 natural gas furnace in the garage and a York air conditioner outside (not sure of the model).
I was thinking about getting this
Honeywell Universal 7-Day Programmable Touch Screen Thermostat.
I like the big screen and the ability to program all 7 days differently. I was going to buy a similar Lux model, but I read on this site that they aren't the best.
I plan on installing it myself.
Please let me know what you think and any suggestions you have!
Thanks,
Monkey
monkeystomach is offline   Reply With Quote
Old 02-04-2010, 08:34 PM   #2
Hvac Pro
Those are good. Make sure you shut off the power to the furnace AND carefully note and label the wires on the old one before removing them and read the wiring info on the new one before doing anything.
Old 02-04-2010, 08:50 PM   #3
DIY Home owner
I have a LUX, it was cheap but works just fine. However, Honeywell is probably much better. Keep in mind that a 7 day programmable thermostat is great and all if your schedule is different every day. If you're like me and work the same schedule Mon-Fri, try to save a little money and get a 5/1/1 programmable thermostat where Mon-Fri and all the same, and Sat and Sun are independent.
wherm5150 is offline   Reply With Quote
Old 02-04-2010, 09:21 PM   #4
What about the Honeywell VisionPRO 8000 series. Are they any better? Do I really need a "Pro" to install one?
Old 02-04-2010, 09:49 PM   #5
Hvac Pro
The Vision Pro is a higher grade of tstat with more features. It can be a bit difficult to see in bright sunlight and if you are not really careful and good with your hands can be damaged if you don't install it CAREFULLY to the subbase. Pros like them as they have a lot more features for fine tuning systems. Some of those features are beyond a lot of DIYers needs or understanding. The FocusPro are good for DIYers and the VisionPro is good if you have electrical and good mechanical skills IMO.
Old 02-05-2010, 05:07 PM   #6
Home Air Direct's Avatar
The Honeywell is a very good stat. The Lux stats that you buy at the building center is not the same quality that most contractors are buying. Beware.
I have been using this stat for over four years now and our failure rate has been exceptional compared to the major brands mentioned above.
Braeburn 5300
Good Luck
Settle down! If you were that important, the city would give you lights and a siren for your car
Last edited by Scuba_Dave; 02-06-2010 at 09:43 AM. Reason: removed advertising links & info
Home Air Direct is offline   Reply With Quote
Programmable Thermostat on Pellet Stove WallyB HVAC 1 12-07-2010 10:46 AM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 09:33 AM
Thermostat Suggestions stratman977 HVAC 4 10-21-2009 03:28 PM
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 11:02 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
