Programmable Thermostat Install Q - HVAC - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 03:41 PM   #1
I purchased the 3M Filtrete (3M-22) programmable thermostat and I'm confused on how to install it. Im pretty sure im just over thinking it.
OLD THERMO WIRES:
W | B | G | R | X | O | Y
NEW THERMO WIRE OPTIONS:
C | B | O | W | W2 | Y | Y2 | RH | RC | G | A
This is how I believe I should install:
W - W
B - C (It says that If I have both B and O, I should install B to C and O to O)
G - G
R - RH
X - ???
O - O
Y - Y
Where should the X go?
Thanks!
75meters is offline   Reply With Quote
Old 05-15-2011, 05:03 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
obviously you have a heat pump. what model is your old thermostat?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-15-2011, 05:06 PM   #3
Model #
Its Honeywell. There are a bunch of different sets of numbers so here they are: (i believe its the first one)
LR95329-1
T874R1889
Im thinking that the X might be the common and I may not need it. What do you think?
Old 05-15-2011, 05:19 PM   #4
Rewards Points: 6,652
What happened to the instruction booklet that came with the new thermostat? If you have not checked the website for the 3m filtrete thermo, everything is pretty much right there.
Old 05-15-2011, 05:25 PM   #5
I have the book. And i've checked the site and all over other forums. The book dosent mention anything about an X wire so I posted up here. My system wires dont seem to properly match up with the new thermo. Any ideas?
Old 05-15-2011, 05:31 PM   #6
JJboy's Avatar
(R), Red conductor, hot side of transformer
(C) or (B) or (X), Blue, Black or Brown conductor, Common side of transformer. Not to be confused with (B) on heat pumps. If you have a (B) on a heat pump thermostat, your common will be (C) or (X)
(Y), Yellow conductor, 1st stage compressor contactor (cooling for ac or cooling and heating on a heat pump).
(Y2), Blue or Pink, second stage compressor contactor
(W), White conductor, 1st stage heat (gas furnace, oil furnace, electric resistance furnace (auxillary heat on a heat pump)
(W2), Pink or any unused color conductor, second stage of heat
(G), Green conductor, furnace blower fan.
(O), Orange conductor, Energize heat pump reversing valve to cool
(B), Blue or Orange, Energize heat pump reversing valve to heat (mainly older Rheem/Ruud).
(E), blue, pink, gray or tan conductor, emergency heating strips on a heat pump.
(T), Tan or Gray conductor, outdoor temperature compensator.
(L), Blue, brown, tan or gray conductor, service indicator lamp.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 05-15-2011, 05:33 PM   #7
Great thanks!
W - W
B - It says "If you have O and B, connect O to O. WARNING: DO NOT connect B to B"
(Where do you think I should connect B to?)
G - G
R - RH
X - Tape up and not use?
O - O
Y - Y
Old 05-15-2011, 06:22 PM   #8
AKA HVACTECHFW
some old systems used both O and B. what kind of heat pump and furnace or air handler do you have? How old are they? Can you access the terminal strips in the equipment? This is the only true way to know what goes where and if your new stat will even work with your system. Does your old stat have a emergency heat function?
IT IS WHAT IT IS
Old 05-15-2011, 07:21 PM   #9
Got it!
Thanks for your help but I got it working.
X goes to C
B Do not use
W goes to W2
The others match up to their letter.
Thanks again
programmable thermostat and quadr fire pellet stoves jec HVAC 1 01-12-2011 09:11 PM
Thermostat Install Help funny wire jhare215 HVAC 15 01-05-2011 09:11 PM
Question on installing an Honeywell RTH6350 programmable thermostat. outdoorted HVAC 3 01-02-2011 06:48 PM
Trying to install new thermostat Jeff240sx HVAC 4 07-01-2010 11:06 AM
Programmable thermostat with aux and emergency heat recommendation bjwz24 HVAC 3 01-25-2008 04:14 PM
