Programmable Thermostat For Hydrotherm HC-145 Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 09:16 PM   #1
Programmable Thermostat for Hydrotherm HC-145 Boiler
Hello. I'm hoping someone here can lead me in the right direction...
I have a Hydrotherm HC-145 boiler and would like to replace my existing manual thermostat with a Trane programmable thermostat (manual can be found here: http://www.trane.com/residential/dow...structions.pdf)
I am having a tough time figuring out if this termostat is compatible with the boiler. The current thermostat has only 2 wires. It looks like these wires are connected to the T1 and T2 terminals on the boiler. There is a third wire running from the boiler to the thermostat but it isn't connected. My understanding is that I can use this to power the thermostat and use the 2 existing ones to turn the heat on/off. I am just not sure where to connect the third wire on the boiler and what terminals on the thermostat to use for all three wires.
Any help is greatly appreciated.
Thanks,
Mike
mikelawr is offline   Reply With Quote
Old 10-30-2011, 10:06 PM   #2
how
Rewards Points: 1,102
I have not used that thermostat but
I would think that you only need to connect the 2 wires from your boiler to the (RH) & (W1) on that stat.
I don't know how the third stat wire would help your boiler?
how is offline   Reply With Quote
Old 10-30-2011, 10:32 PM   #3
My understanding is that the existing two wires are used just to turn on/off the boiler, but that there needs to be another wire to actually power the thermostat clock, etc. since there are no batteries.
Thanks,
Mike
Old 10-30-2011, 10:54 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
that thermostat need 24VAC power and therefore needs all three wires. You need to measure voltage from T1 to ground and T2 to ground. Which ever terminal shows 24V to ground is wired to R, the other terminal goes to W and your third wires goes from boiler ground to C on stat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-31-2011, 09:00 AM   #5
Thanks very much!
Old 11-04-2011, 12:02 PM   #6
One more follow up question since I am a novice... I looked at the boiler and was unable to figure out where the ground is. Any ideas? The thermostat connection looks similar to pic 6 and 7 in this album that someone else posted online:
http://s307.photobucket.com/albums/n.../boiler-relay/
Thanks again...
-Mike
Old 11-04-2011, 06:14 PM   #7
AKA HVACTECHFW
The ground would be any cabinet screw
IT IS WHAT IT IS
Help Wiring Programmable Thermostat Brio9 HVAC 4 02-14-2011 12:25 AM
Programmable thermostat and zone issues bawinnicki HVAC 7 01-10-2011 11:23 AM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Boiler still runs even when thermostat is off jamegail1 HVAC 25 10-05-2010 03:21 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
