Programmable Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 08:17 AM   #1
programmable thermostat
hi all
need some help just installed a new
gmh950904cx two stage goodman furnace
and
gsx130361 3 ton 13 seer ac unit
need help for the right programmable thermostat
for the equipment to run the best it can right now
i have a whiterogers 80 series 1f80-361 single stage programmable thermostat
thanks all dan
leiut56 is offline   Reply With Quote
Old 08-23-2011, 05:01 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
While it is a 2 stage Furnace it only uses a single stage stat due to goodman's "Dual Saver technology". Too bad you did not opt for the true 2 stage system with the variable speed blower to have total control of the 2 stage heating from the stat. The stat you have will work well with the system.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-23-2011, 05:59 PM   #3
An old Tradesmen
Rewards Points: 6,544
Its still a true 2 stage.
It simply is not controllable by a 2 stage thermostat to get the best comfort possible from a 2 stage furnace.
The Following User Says Thank You to beenthere For This Useful Post:
Doc Holliday (08-23-2011)
Help Wiring Programmable Thermostat Brio9 HVAC 4 02-14-2011 12:25 AM
programmable thermostat and quadr fire pellet stoves jec HVAC 1 01-12-2011 10:11 PM
Programmable thermostat and zone issues bawinnicki HVAC 7 01-10-2011 11:23 AM
Line Voltage Programmable Thermostat for Off-peak studhauler Electrical 4 05-11-2010 05:38 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
