Programmable Line Voltage Therm For Fan Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 07:23 PM   #1
Question
programmable line voltage therm for fan heat
My cottage has a heat unit installed at the bottom of the bathroom sink vanity enclosure. The other units in the house are electric baseboard units but this is a box that sits on the floor basically and blows heat into the bathroom. Don't know the model or brand. Right now there's a simple white knob hi/low line voltage therm installed on the wall that controls it but I'd like to change that to a more sophisticated line voltage programmable one.
The only one I've found is the Aube TH115 and it says electric heat only. It seems to constantly vary the voltage instead of just turning it on and off as the present one does. Is this OK to use with the fan unit? Or does anyone have another suggestion?
thanks for any help!
nykije is offline   Reply With Quote
Old 11-18-2009, 09:51 PM   #2
Unhappy
I don't know the specs. of that particular model. But when it says "(Electric) Heat Only" it means only resistive loads, like heating elements and no INDUCTIVE loads, like fans or Fluorescent lights. Including CFL.
spark plug is offline   Reply With Quote
Tags
line voltage therm
Remote sensor for line voltage thermostat? hbridge HVAC 7 07-06-2012 03:42 PM
Low Voltage vs. Line Voltage for under-cabinet Crashless Electrical 26 02-03-2011 08:40 PM
Low profile junction box or distribution block for line voltage undercabinet lights ? Bluelude1 Electrical 2 05-01-2008 07:52 PM
transformer schematic walt1122 Electrical 10 01-05-2008 03:45 PM
Problem with line voltage mehranalmasi Electrical 21 07-04-2007 06:12 AM
