Programmable Backlit Thermostats - HVAC - DIY Chatroom Home Improvement Forum
Old 03-09-2008, 03:41 AM   #1
Programmable backlit thermostats
I have a home with hydronic heat and old timey round thermostats in each bedroom. I wanted to put something accurate, good looking, and programmable as a replacement so I bought 3 Honeywell RTH7400 thermostats thinking that they matched what I need and coming from Honeywell they would be the best. Unfortunetely, there are two features that are simply unacceptable:
First, the backlight will not turn on unless you press a button. This is just dumb.
Second, this things makes the loudest relay clicking I've ever heard from a thermostat. This just won't do.
I have a nice White Rodgers touchscreen thermostat (on the first floor) and it does not have either of these problems.
So besides paying the big bucks for something really nice, does anyone make a good thermostat? These things are really priced way too high, there must be some competition out there. All I need is something with one switching relay in it, but I want it to come in a nice package.
Thanks,
Chris Hansen
invertedflight is offline   Reply With Quote
Old 03-09-2008, 09:45 AM   #2
biggles's Avatar
did you check out the Honeywell Vision Pro 8000 http://www.hotfreshcool.com/visionpro_demo.html
Old 03-10-2008, 10:45 PM   #3
Like, I said, I need four units and don't want to drop $100+ on each. I think I may have found a solution - will post back soon.
-Chris
Old 03-11-2008, 06:44 AM   #4
biggles's Avatar
might be able to add a remote sensor the size of a matchbook ,and mount the stats in a hallway closet or down near the boiler on 3/4" plywood
Old 03-27-2008, 02:47 PM   #5
Hi,
well you could get another white rogers touchscreen for an inexpensive price . Try this link and see if you find another touchscreen white rodger thermostat that could work for you.
Jane
Jane Addams is offline   Reply With Quote
recommend Heat only programmable thermostat? pesphoto HVAC 11 12-26-2007 07:26 PM
What do you keep your programmable thermostat set to J187 General DIY Discussions 2 12-08-2007 11:05 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
Baseboard thermostats gregrice HVAC 7 01-08-2006 08:10 PM
