Program Luxpro Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2010, 11:14 AM   #1
Program Luxpro thermostat
I want to cancel program and use setting manually. How? Luxpro PSP511C. (Was able to change the time, that is all I knew how to do) Thanks.
Lenore is offline   Reply With Quote
Old 11-14-2010, 11:46 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
Check it out:http://www.luxproproducts.com/support.html
Old 11-14-2010, 11:50 AM   #3
Program Luxpro
I can read but I still can't understand how to do it. Need step by step instruction. Even have the written operating instructions in my hand.
Old 11-14-2010, 11:55 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 396
Take a break for 10 mins then carefully read the section where it says using "Temperature Hold"
http://www.luxproproducts.com/pdfs/P...ENG_Manual.pdf
Old 11-14-2010, 12:48 PM   #5
Temperature Hold
I think it worked. I just opened the door, arrow was on "run",then pressed the "hold" button. In window it now says"hold". Someone else programmed it with w/e,nights,etc. I now work eves.,want it to be 62deg. when I am away.So you think that it will be that set temp until I set it by just using arrows "up" or "down"? Thanks. L
Old 11-14-2010, 01:01 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 396
It will stay there forever ( you can raise and lower it however you like) unless you press Hold again which then runs the setback program. If you switch it from heat to off or ac then it releases the hold and runs the program
Help with LuxPro PSP722E Thermostat edfiero HVAC 9 12-06-2010 06:31 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Help Needed - Program Honeywell Prestige Thermostat hennyh HVAC 2 11-19-2009 05:59 PM
Need Help with Luxpro 722E Thermostat tedzia HVAC 1 07-23-2008 05:18 PM
