Progammable Thermostat Common Wire - HVAC - DIY Chatroom Home Improvement Forum
Old 07-06-2010, 04:24 PM   #1
I am installing a new programmable thermostat (Hunter 44860) but would like to have it use the household electricity and not just run off of the batteries. My current thermostat is a 3 wire setup (Y-RC-W, with jumper from RC to RH). I plan on running another wire to connect the common leg to C on the thermostat, but where does it connect to? Currently the RC wire is connected to a 24V transformer off in the basement. Thanks in advance for any help.
72 Z27 is offline   Reply With Quote
Old 07-06-2010, 05:55 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
On your furnace transformer there is a hot (R) and common (C). Put your new C on the opposite terminal to the RC on the transformer or the C on the circuit board. The return from the AC also has to go to C so you can trace it back from there.
troubleshoot thermostat 6 wire GR Berger HVAC 3 04-08-2010 08:24 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Replacing my 6 wire Honeywell condo thermostat Ivan33 HVAC 8 11-29-2009 01:04 PM
Thermostat wiring question Yail Bloor Electrical 5 09-13-2009 01:57 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 03:45 PM
