Procom Heater Need Help Bad - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 07:58 PM   #1
procom heater need help bad
just bought a procom lp wall heater for my garage does anyone know how ton unscrew the ignitor cap to install the battery?
Can I run it on a flexible propane line with a regulator from a grill?
Any help would be appreciated, thanks.
newhomeowner111 is offline   Reply With Quote
Old 11-19-2011, 09:20 AM   #2
Rewards Points: 1,520
Did you read the owner's/installation manual?
bob22 is offline   Reply With Quote
Old 11-20-2011, 11:21 AM   #3
yes i did
yes i did but its so vage and the guy at tractor supply where a bought it new nothing about these heater
Old 11-24-2011, 06:12 PM   #4
procom has a tech phone number for help 1 -880-222-5381 ext 2 week days
just installed lp procom --can not get pilot light to lite- have 225 lb tank
maybe Ben will help us-----
jonni is offline   Reply With Quote
Old 11-24-2011, 06:15 PM   #5
oh yeah----
I think you should have at least 100 lb tank
the tech should tell you for sure.
Old 11-24-2011, 06:33 PM   #6
Rewards Points: 582
Hi if you are using propane gas...YOU CAN NOT USE REGULATOR FROM GRILLE..you need a high pressure external dual regulator. pressure set 11-14" of w.c...all manuals for these heater state...self install is not permitted all warranty void if not installed by license gas installer
Old 11-24-2011, 09:30 PM   #7
call procom tech number the correct no is
1-877-886-5989
listen to what BEN says!
hope this helps
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 08:31 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
