Problems With New System - HVAC - DIY Chatroom Home Improvement Forum
Old 09-15-2008, 12:52 PM   #1
Problems with New System
I had a new condencer, furnace and evaporator installed about 3 weeks ago. Just about a week and a half ago, I woke up one morning realizing that the AC must have run all night. I checked and not cold air was blowing out of the vents. I found that the pipe going into the evaporator and the pipes outside going into the compressor were frozen. I thawed and ran the system. Over the past week this has been a regular occurance. The odd things is that it happens at night and first thing in the morning when I guess the outside temps are cooler. I have no idea if this has anything to do with it or not but I ran the system yesterday afternoon and got cool air, and no freezing.
Do I have a refridgerant leak? Sometimes when the system shuts down I can hear some sort of squealing noise coming from the evaporator. It's nothing mechanical. Almost like somethig is escaping from the pipe.
I have the guy coming over that installed the system but would like some input on what the problem could be or questions to ask.
Thanks.
Boomersooner is offline   Reply With Quote
Old 09-15-2008, 01:32 PM   #2
Rewards Points: 1,088
Thanks.
Yup, either that, or the system was never filled with refrigerant.
handy man88 is offline   Reply With Quote
Old 09-15-2008, 03:07 PM   #3
It sounds like the system might not have been fully charged to begin with. When the tech checks the charge ask him to write down all the temps, especially superheat and subcool. If he has to charge it, ask for the numbers afterwards. You could check the charge yourself to verify what the tech has done. If he's not checking your charge correctly this will put him on notice to do it right, or at least that you might check his work.
dac122 is offline   Reply With Quote
Old 09-15-2008, 03:33 PM   #4
After the charge, the tech should also use something like Snoop Leak Detector to make sure all fittings are tight and there are no pinhole leaks.
Old 09-15-2008, 04:53 PM   #5
He came and checked and found nothing wrong. Said the system is not leaking and he did not have to add refridgerant. He did say that it is possible there is an issue with the compressor. He is looking into the replacement under warranty.
Old 09-15-2008, 09:18 PM   #6
What's the make? Don't say Goodman.
Old 09-16-2008, 07:40 PM   #7
Why are you running your ac at night? Isnt your house cool enough at 9 or 10 to shut it down or at least raise the setpoint? It does sound as though there may be a refrigerant charge issue.
statman is offline   Reply With Quote
Well system problems Offalot Plumbing 2 07-10-2008 06:00 PM
New House, new system, poor cooling Faulknertw HVAC 15 07-08-2008 10:06 PM
Steam heating system problems Need HELP smay0808 Plumbing 7 11-05-2007 11:17 PM
Problems with Central Air Cooling System golfgod04 HVAC 4 05-27-2007 08:51 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 10:56 AM
