Problems With Honeywell Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-15-2011, 01:12 PM   #1
Problems with Honeywell Thermostat
I recently purchased and installed a Honeywell RTH6400 thermostat to run my Lennox G40UH series gas furnace. The problem is that the thermostat will not activate the furnace until there is a 2 degree Celsius difference between the room temperature and the set temperature. Is this a faulty thermostat or can I change this setting? I could live with one degree difference, but 2 is not acceptable. Thanks.
gerryyf is offline   Reply With Quote
Old 01-15-2011, 01:39 PM   #2
Rewards Points: 6,652
Did you go through the programming of the thermostat to set for the furnace type & CPH?
Old 01-16-2011, 09:58 AM   #3
Rewards Points: 494
http://customer.honeywell.com/techli.../69-2210EF.pdf
On page 20 when choosing fahrenheit or celcius, see if another function for offset. If so, offset 2 degrees C.
Another posting reminds that if hole remains in wall, where wiring comes through, cold air may be hitting thermostat from the back. Seal wall hole temporarily with tape to test?
diyorpay is offline   Reply With Quote
Old 01-16-2011, 11:29 AM   #4
An old Tradesmen
Rewards Points: 6,928
That stat uses CPH, so there is no offset adjustment.
Did you set the stat to something other then 1 heat 1 cool?
Old 01-16-2011, 12:36 PM   #5
HVAC Installer
on the honeywell stat there is an option to selet Comfort or economy. I am willing to bet you are on economy. This will not allow the furnace to start till there is a 2 degree call, that way the furnace runs longer less often. Switch it to comfort and that should take care of it.
LukeROttinger is offline   Reply With Quote
Old 01-16-2011, 01:10 PM   #6
Not on that thermostat. It is a really basic model.
Honeywell Vision Pro 8000 TH8320U1008 Thermostat Question chetwynd HVAC 3 02-08-2012 10:36 AM
Honeywell Thermostat/ With Nordyne A/C single package 4 ton h.p. NanaMcal HVAC 0 12-08-2010 09:53 AM
Honeywell RTH7600D Thermostat brewmastr HVAC 1 01-03-2010 08:10 PM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 01:30 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
