Problems With Furnace Not Heating - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2013, 04:35 PM   #1
Problems with furnace not heating
I have a Carrier Weather Master 9200. I have tried everything I can find on the internet to try and it still doesn't work. I am getting an error code 31. I have tested the heating sensor and it tests fine, I have checked to make sure there are no clogs in the tubes connected to the pressure switch, I tried to bypass the pressure switch but still cannot get heat. The blower initially kicks on and runs for about 90 seconds before shutting off. What else can I possibly try before I have to call a repair person?
mal927 is offline   Reply With Quote
Old 11-11-2013, 05:02 PM   #2
An old Tradesmen
Rewards Points: 6,112
Check the roll out switches.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 03:13 PM
Carrier Gas Furnace - Problems with Ignition jean004 HVAC 33 01-17-2012 02:26 AM
armstrong furnace problems snipe609 HVAC 1 01-29-2011 10:25 AM
furnace stops heating ashmay HVAC 1 01-16-2011 12:05 PM
Carrier furnace problems BigK75 HVAC 1 07-30-2009 06:16 PM
