Problems With Dayton 5UT20 Hot Water Garage Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2009, 12:07 AM   #1
Unhappy
Problems with Dayton 5UT20 hot water garage heater
I am having trouble getting this heater to put out any sort of substantial heat. I plumbed it into the boiler loop with 1/2" pex tubing and I'm thinking that is the root of my problem. I have 5 zones in my system and the garage heater is the only heater on that zone. I'm getting good circulation and the boiler system is set at 180 degrees. I live in the Dakota's and it won't even bring the temp up high enough to register on a thermostat. Any ideas on what I could check or change? I'm about ready to just buy a electric garage heater and give up on using hot water? I have a two car insulated garage.... Thanks for any future replies!
tcellis is offline   Reply With Quote
Old 03-16-2009, 04:23 AM   #2
An old Tradesmen
Rewards Points: 6,846
What is the entering water temp at the heater, and what is the leaving water temp at the heater.
Old 03-16-2009, 05:47 AM   #3
biggles's Avatar
the grainger catalog calls for 200F inlet temp with a 20F drop going back out,and shows a 1-1/4" inlet supply.if the piping is anything less then that it could be effecting the heat coming off the coils. http://www.grainger.com/Grainger/wwg...34&submit.y=11 check the incoming air temp and whats going out.
Old 03-17-2009, 03:28 PM   #4
Mainah's Avatar
what temp do you have the contol set at to turn the blower on?
Mainah is offline   Reply With Quote
Gas Hot Water Heater - Help? MaximumAsh Plumbing 22 03-13-2009 10:57 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
