-   -   Problems with Dayton 5UT20 hot water garage heater (http://www.diychatroom.com/f17/problems-dayton-5ut20-hot-water-garage-heater-40431/)
tcellis 03-16-2009 01:07 AM
I am having trouble getting this heater to put out any sort of substantial heat. I plumbed it into the boiler loop with 1/2" pex tubing and I'm thinking that is the root of my problem. I have 5 zones in my system and the garage heater is the only heater on that zone. I'm getting good circulation and the boiler system is set at 180 degrees. I live in the Dakota's and it won't even bring the temp up high enough to register on a thermostat. Any ideas on what I could check or change? I'm about ready to just buy a electric garage heater and give up on using hot water? I have a two car insulated garage.... Thanks for any future replies!
beenthere 03-16-2009 05:23 AM
What is the entering water temp at the heater, and what is the leaving water temp at the heater.
biggles 03-16-2009 06:47 AM
the grainger catalog calls for 200F inlet temp with a 20F drop going back out,and shows a 1-1/4" inlet supply.if the piping is anything less then that it could be effecting the heat coming off the coils. http://www.grainger.com/Grainger/wwg...34&submit.y=11 check the incoming air temp and whats going out.
Mainah 03-17-2009 04:28 PM
what temp do you have the contol set at to turn the blower on?
