Is This A Problem? (what I Found In My Attic) - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2014, 09:27 AM   #1
Rewards Points: 36
Question
Is this a problem? (what I found in my attic)
Our house is in central Nebraska. It's about 12 years old and we're the 2nd owners. Utility bills aren't outrageous.
The house is a split-level with walk-out basement. The view you see is above the main-level bathroom - which is above the basement bathroom. I found it odd that the bathroom ceiling vents aren't directed outside, they are vent into the attic space (not shown, but is near the PVC pipes). No signs of moisture or mold up there. I'm assuming the sheet metal pipe is a furnace vent.
So ... is this OK? If not, what do you recommend? (I'm trying to learn.)
Mike
central NE
Is this a problem? (what I found in my attic)-100_5941.jpg   Is this a problem? (what I found in my attic)-100_5942.jpg   Is this a problem? (what I found in my attic)-100_5943.jpg   Is this a problem? (what I found in my attic)-100_5944.jpg
Mike68847 is offline   Reply With Quote
Old 02-19-2014, 09:37 AM   #2
Rewards Points: 13,270
Needs to be vented all the way out the roof.
Looks like there's already a vent through the roof no one connected the pipe to.
And no you can not just tap into the steel pipe that's there now.
Any idea what those 2, small PVC lines are for?
Old 02-19-2014, 10:08 AM   #3
Rewards Points: 36
No idea about the PVC; I assume they are associated with the two bathrooms. As for the furnace pipe, I just pointed it out as what I'm fairly sure it is for the readers of this post. Does it look OK?
And I'll work on venting the bathroom exhaust fan vents to the outside.
Old 02-19-2014, 12:55 PM   #4
Rewards Points: 692
Before you lock in on a roof vent search the forum for vent ice dam to determine if you really want to do that.
SeniorSitizen is offline   Reply With Quote
Old 02-19-2014, 01:48 PM   #5
Rewards Points: 36
Will do; thanks.
Old 02-19-2014, 01:58 PM   #6
Rewards Points: 692
You may also want to read reply #4 in this thread to gain more knowledge.
Bathroom fan duct by n0c7
Tags
attic , vents
Moisture and Frost in the Attic Cenzo22 Roofing/Siding 10 12-03-2012 03:32 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Attic fan options P550 Roofing/Siding 1 08-22-2010 01:47 PM
venting and moisture in attic Alto Roofing/Siding 3 07-29-2010 10:31 PM
