Problem With In Wall Dryer Duct. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 02:00 AM   #1
Rewards Points: 682
Problem with in wall dryer duct.
Our condo has a washer and dryer closet in the kitchen. The exit duct for the dryer enters back wall of the closet at a level of 2 feet above the floor, and inside the wall runs straight up to the ceiling, where it makes a 90 degree turn and then runs horizontally about 6-8 feet inside the ceiling (above a downstairs shower stall) to the outside wall.
With a moisture detector I found there is a lot of moisture in the wall along the vertical section of the duct. Since the previous owner did not hook up his dryer to this duct, I was worried the pipe had somehow ruptured inside the wall and spewed moist air in the wall space for years, forcing the former owner to abandon this duct.
A neighbor told me that this was a common problem, because of poor design moisture settles downward in the pipe and in the walls. He suggests the duct isn't broken inside the wall at all.
What do you guys think? We are planning to install a new washer and dryer, betting the pipe is intact, do you guys think this is a good idea?
darsunt is offline   Reply With Quote
Old 01-30-2012, 03:57 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Can you get access to the attic where the pipe comes up the wall to shine a light down inside it?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-30-2012, 11:33 AM   #3
Rewards Points: 682
No, there is a second floor, the pipe is between the floor and the ceiling.
Old 01-30-2012, 11:40 AM   #4
Albo Andy built another condo I see.
hvac5646 is offline   Reply With Quote
Old 02-02-2012, 12:17 PM   #5
Rewards Points: 682
I don't get the joke
Old 02-02-2012, 01:23 PM   #6
Rewards Points: 13,300
It's a very poor layout for a dryer vent. Way to long and to many turns.
Must take a long time for the clothes to dry.
Duct in exterior wall kbennett HVAC 1 12-12-2010 08:22 PM
Dryer Vent Leaks Water glennonr General DIY Discussions 9 04-23-2010 08:50 AM
Dryer duct problem riverrite Appliances 6 02-22-2010 09:31 PM
Hole in my dryer duct... QuattroStylez Building & Construction 6 11-30-2008 05:11 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
