Problem With Trane XE78 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-25-2008, 02:12 PM   #1
Problem with Trane XE78
Having problems with my approximately 15-year-old Trane XE78. A couple of days ago it started to smell like electrical overheating type smell coming out of the vents. We have two units in the house one upstairs and one all the way downstairs itís the unit downstairs that is producing the smell. It also seems to be louder when it kicks on. I switched it off and saw a blinking light on a circuit board. It appears to be blinking continuously so I canít tell how many blinks. Please keep in mind I have no experience in this type of repair so pictures would be helpful if you know of a website that uses pictures, or any ideas if I have to call a repairman so I can give the impression that I have even a small clue
Bruno2005 is offline   Reply With Quote
Old 12-25-2008, 02:27 PM   #2
Electrical Contractor
kbsparky's Avatar
Burning smell coming from the environmental air is a sign of a bad connection in your aux strip heaters, or bad element, etc.
You might want to have a competent service person check this one out. Too much at risk (fire, smoke, etc) to ignore ....
Old 12-25-2008, 03:04 PM   #3
Thank you think we will be calling one tomorrow.............looked at it again since I posted and it almost sounds like the blower motor maybe burning out. Thanks again for your expertise
Old 12-25-2008, 04:37 PM   #4
An old Tradesmen
Rewards Points: 8,154
I think you'll find a Trane XE78 is a gas furnace.
No strip heaters.
Trane XL1200 - Outdoor Unit Problem snifred81 HVAC 5 08-07-2012 01:53 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Trane XE 80 Problem Espy HVAC 2 11-18-2008 05:31 PM
Trane XE 80 Problem ShotgunW HVAC 14 12-30-2007 09:00 PM
Trane 80xl, 3 flashes error light - draft pressure problem, help? Xsta HVAC 1 10-14-2007 08:20 PM
