Old 07-19-2012, 09:06 AM   #1
Problem: Replacing Honeywell T6960 with Honeywell TB6575
Hello All,
I am trying to replace my old T6960 Fan Coil thermostat with a SuitePRO TB6575. Everything works as it should, except:
If I try to select any fan speed besides low, all the screen options light up for one second and then the entire system shuts off and resets. Any thoughts on what I have messed up? Also, it also seems like the thermostat's low setting is actually running the fan at high.
Any ideas? I can provide photos, include more info, etc.
Honeywell T6960 installation instructions:
http://customer.honeywell.ca/techlit.../95C-10678.pdf
Honeywell SuitePRO TB6575 installation instructions:
http://s3.pexsupply.com/manuals/1286..._PROD_FILE.pdf
RT2020 is offline   Reply With Quote
Old 07-21-2012, 03:05 AM   #2
Houston204's Avatar
Is this a 2 pipe or a 4 pipe application?
If this is a 2 pipe do you have boiler or chill water?
Which Fig. in the old manual shows your application?
Which Fig. did you use in your new application?
Do you have pictures of the initial wiring as well as the new stat wiring?
Post the pics that you have...
www.photobucket.com
Houston204 is offline   Reply With Quote
Problem with Honeywell Interface Module THM5421C usa-2 HVAC 2 10-23-2011 12:26 PM
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 09:32 AM
Honeywell Zone valve problem gnosti83 HVAC 3 01-12-2011 09:55 AM
Weird problem replacing dimmer switch cdale600 Electrical 9 01-20-2009 09:31 AM
Honeywell RTH7000 and Goodman System Problem jvd1812 HVAC 1 11-08-2008 12:51 PM
