Problem With Radiator - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 07:34 PM   #1
Problem with Radiator
Any easy ways to fix it if the pipe is clogged?
fecer is offline   Reply With Quote
Old 12-19-2009, 08:09 PM   #2
Do these ever get clogged? If they do is there any simple way to unclog them?
Old 12-19-2009, 08:30 PM   #3
Never known one to clog. Could be air-locked or a frozen pipe.
SKIP4661 is offline   Reply With Quote
Old 12-19-2009, 08:52 PM   #4
An old Tradesmen
Rewards Points: 7,384
Very seldom will one clog.
most times. A place just has low water pressure in the system.
What pressure is your system at. And how high above teh boiler are these rads.
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
Radiator Problem yanks2009 HVAC 3 10-15-2009 12:19 PM
septic problem??? jjrbus Plumbing 2 09-09-2009 09:59 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
