Problem With Payne Ultra 90 - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-30-2007, 09:34 PM   #16
no loose ends
After reading the ongoing postings to this thread, it has become clear that the furnace you have is older than previously assumed and this unit has no LED on said board. I am glad however that thing are working!
Originally Posted by Mark H View Post
Maybe I'm missing something but I do not see any type of LED display on the board. However, I did not find the board until after the last time I reset the furnace and it has been running flawless since then. Will there be any code shown if it is operating correctly?
undone is offline   Reply With Quote
Old 12-30-2007, 09:56 PM   #17
Thanks undone, I'm learning as I go from you guys and thank you all for your time. I guess I should have mentioned my furnace is probably 22 years old since that is the age of my house. I have only lived here for 5 years though, so I have no history prior to that.
I am however beginning to think I am learning enough about my furnace to really get myself into trouble! The good news is it is still working flawlessly going on 3 days now.
Mark H is offline   Reply With Quote
Old 12-30-2007, 10:10 PM   #18
no loose ends
Do you recall the last step you perfomed prior to your "success"?
Old 12-30-2007, 10:35 PM   #19
Well, I did my first post in these forums shortly after the last time I had to restart the furnace. Since then I checked both inlet and exhaust and both were clear. I checked every terminal, wire, plug, and hose connection I could find, twice! I checked all my supply registers and found 5 of 16 closed and opened them.
So, there are 3 possibilities. I moved a wire or plug that was not making a good connection, the 5 closed registers were causing the problem (I doubt this). Or, i have fixed nothing and it is just on a good streak. like I mentioned in the beginning, sometimes it will run for a whole week perfectly before it acts up. Sometimes I'm resetting it 5-6 times a day.
Old 12-31-2007, 09:25 PM   #20
Update! My furnace is acting up again. I just had to restart it but I think know whats wrong. This time before I restarted it by shutting everything off I opened the compartment with the main control board. I noticed that the one big relay on it would activate when I closed the door interlock and the furnace still did not come on so I tapped on the other relay...nothing happened. I then pulled the plug going to the card and then plugged it back in. The relay I was tapping on sparked (inside, its the old type with the clear plastic case) and the inducer fan immediately started and everything else in turn. So I'm hoping the card I bought will fix this!
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 04:55 PM
Phone Jack Hookup Problem kennykenny Electrical 18 12-07-2007 04:48 PM
1994 camry rear suspension/tires problem marks5894 Automotive Repairs 2 11-05-2007 06:12 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
