Problem With Honeywell Wifi Smart Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2013, 09:54 AM   #1
Question
Problem with Honeywell wifi Smart thermostat
Hi,
So i have the Honeywell wifi thermostat. i have forced air AC , and a Steam heat with radiators. I purchased this thermostat in the summer and set it up. I'm not using the C wire because i didn't have it, instead i used the G wire installation, where i used the G wire as my C wire and then in the AC unit's panel i move the G wire to the C terminal, i then used a jumper wire to connect terminal Y and G together. The only wires that come from the heater system are the white wire that I placed in the W-O/B port and a red wire which i placed in the R port in the thermostat.
So my problem is now it getting cold and i go and try my heating system and it doesn't work. what happens is the fan form the AC turns on (which i don't use during the winter) but my heat doesn't come on.
here is a picture to show what I did on the thermostat.
So is the Honeywell optimized for my type of home cooling and heating and if it is what am doing wrong?
Thank you!!
ALBRI98 is offline   Reply With Quote
Old 10-25-2013, 02:33 PM   #2
An old Tradesmen
Rewards Points: 7,376
Which model number thermostat is it.
Old 10-26-2013, 12:11 AM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Do you have it setup for electric or gas heat? I recommend running a new wire for C also.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-26-2013, 12:52 AM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
I recommend you call an Hvac tech!
Who replaces their Tstat and doesn't run it through heat and a/c cycles before you actually need them!?
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
gregzoll (10-26-2013)
Old 10-26-2013, 05:14 PM   #5
It's the RTH9580wf
Old 10-26-2013, 05:36 PM   #6
An old Tradesmen
Not familiar with that one.
In installer set up. You did tell it 1 heat 1 cool.
Old 10-26-2013, 06:25 PM   #7
Rewards Points: 6,652
Expensive sucker. Costs as much as the Nest. It is basically the Prestige Beenthere. Now if the OP is not using it with the Internet connected capabilities, they threw away a lot of money, that they did not need to spend on that thermostat.
See http://www.thermostatforums.com/show...fi-thermostat& http://yourhome.honeywell.com/home/P...Thermostat.htm
Old 10-26-2013, 06:51 PM   #8
AKA HVACTECHFW
Its a prestige that doesn't have near the capabilities of the professional version.
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
Old 10-26-2013, 09:30 PM   #9
You have that correct.
Old 10-26-2013, 10:52 PM   #10
Question
Yes I did.
Old 10-26-2013, 11:08 PM   #11
An old Tradesmen
Did you remove the R to RH jumper.
Old 10-26-2013, 11:22 PM   #12
Yes I did.
Old 10-26-2013, 11:26 PM   #13
An old Tradesmen
Did you select equipment controls blower, in heat set up.
Old 10-27-2013, 08:11 AM   #14
I didnt get that setting when setting up.
Old 10-27-2013, 08:20 AM   #15
An old Tradesmen
If your blower is coming on. With the way its wired, the A/C should of came on also. Did it.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (10-27-2013)
Honeywell WiFi Thermostat install help I26 HVAC 22 07-13-2015 07:55 AM
Thermostat C Wire Problem spollard888 HVAC 19 11-29-2013 04:09 PM
Thermostat problem - C wire? hoboat HVAC 2 06-11-2013 09:19 AM
A/C not working - thermostat problem? pro_DIYer HVAC 11 10-18-2012 01:38 PM
The Right Thermostat? (Honeywell says two diffrerent things) FourIsWaltz HVAC 3 10-10-2010 08:20 PM
