Problem With Honeywell Interface Module THM5421C - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 10:59 AM   #1
Problem with Honeywell Interface Module THM5421C
Relocated my thermostat, and may have shorted two wires. Could that cause the Honeywell Interface Module (THM5421C) to stop working? If so, can it be fixed, or do I need to replace it?
usa-2 is offline   Reply With Quote
Old 10-23-2011, 11:17 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
I short can mess up any board. Does this module have a low voltage fuse on it? Usually on boards that do have a fuse it will be the first to blow in this instance, component protection.
Doc Holliday is offline   Reply With Quote
Old 10-23-2011, 12:26 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
are you sure you have 1 2 3 wired the same at stat and EIM?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Kenmore Ice Maker Module Problem oregonlee Appliances 12 12-29-2008 05:37 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 07:10 PM
Honeywell RTH7000 and Goodman System Problem jvd1812 HVAC 1 11-08-2008 12:51 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
