Old 10-04-2009, 10:08 AM   #1
Problem: Goodman GMNT to Hunter 44155C Thermostat
First time poster here hoping someone can shed some light on my problem...
I have a Goodman GMNT Furnace (Manual)
I just purchased a Hunter Programmable Thermostat 44155C which looks something like this:
My problem is I cannot seem to get the wiring set up correctly. Ignore the wiring in the picture, that is not my photo.
I have a 5 wire thermostat wire coming from my furnace. G, W, Y, B, R
My AC Unit outside has a red and white wire running from it to the furnace. They are tied into the thermostat lines.
Please view my attached schematic for more detail.
I have tried a great many wiring combo's but none seem to work well. The best I can get is the AC and Furnace to turn on at the same time.
Any help would be GREATLY appreciated!
Problem:  Goodman GMNT to Hunter 44155C Thermostat-schematic.jpg
shipupride is offline   Reply With Quote
Old 10-04-2009, 01:26 PM   #2
Wire nut one of the wires from the a/c unit to the blue wire. Then you should follow the r to red, green to g, white to w/b, yellow & the other a/c line to y1. Not being there, I am making an educated guess that the blue is the common connection at the control board. It wouldn't hurt to verify this. Good luck
Flashheatingand is offline   Reply With Quote
Old 10-04-2009, 02:15 PM   #3
GC/Master Plumber/Mech
If this is like the stat you have it is for a heat pump but will work for you so..
Red to RC/RH
Green to G
White to W
Yellow to Y1
and tape off the blue
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-04-2009, 04:25 PM   #4
I thought shipuppride wrote the condensing unit wires are going to the stat, thats why he needs the blue. But after further review..whoops. I stand corrected.
Old 10-04-2009, 04:42 PM   #5
Red to RC/RH
Green to G
White to W
Yellow to Y1
This fixed it! Thanks!!
Old 10-11-2009, 05:36 PM   #6
Hi,
I am having this same problem with a Hunter 44260. After reading the posts I checked my wiring and it is wired as suggested. I have included a photo for clarification. Are there any other options?
Thanks for responding.
reynfill is offline   Reply With Quote
Ford Ranger Thermostat Problem? suzikg Automotive Repairs 15 02-01-2012 11:21 AM
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 10:58 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 01:04 AM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
Thermostat Wiring Problem crazy woman HVAC 2 08-15-2006 10:22 AM
