-   -   Problem: Goodman GMNT to Hunter 44155C Thermostat (http://www.diychatroom.com/f17/problem-goodman-gmnt-hunter-44155c-thermostat-54397/)
shipupride 10-04-2009 10:08 AM
1 Attachment(s)
First time poster here hoping someone can shed some light on my problem...
I have a Goodman GMNT Furnace (Manual)
I just purchased a Hunter Programmable Thermostat 44155C which looks something like this:
http://farm4.static.flickr.com/3429/...047fc733a9.jpg
My problem is I cannot seem to get the wiring set up correctly. Ignore the wiring in the picture, that is not my photo.
I have a 5 wire thermostat wire coming from my furnace. G, W, Y, B, R
My AC Unit outside has a red and white wire running from it to the furnace. They are tied into the thermostat lines.
Please view my attached schematic for more detail.
I have tried a great many wiring combo's but none seem to work well. The best I can get is the AC and Furnace to turn on at the same time.
Any help would be GREATLY appreciated!
Flashheatingand 10-04-2009 01:26 PM
Wire nut one of the wires from the a/c unit to the blue wire. Then you should follow the r to red, green to g, white to w/b, yellow & the other a/c line to y1. Not being there, I am making an educated guess that the blue is the common connection at the control board. It wouldn't hurt to verify this. Good luck
Plumber101 10-04-2009 02:15 PM
If this is like the stat you have it is for a heat pump but will work for you so..
Red to RC/RH
Green to G
White to W
Yellow to Y1
and tape off the blue
Flashheatingand 10-04-2009 04:25 PM
I thought shipuppride wrote the condensing unit wires are going to the stat, thats why he needs the blue. But after further review..whoops. I stand corrected.
shipupride 10-04-2009 04:42 PM
Red to RC/RH
Green to G
White to W
Yellow to Y1
This fixed it! Thanks!!
reynfill 10-11-2009 05:36 PM
1 Attachment(s)
Hi,
I am having this same problem with a Hunter 44260. After reading the posts I checked my wiring and it is wired as suggested. I have included a photo for clarification. Are there any other options?
Thanks for responding.
