Problem With GMAT090-3 Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 04-29-2010, 02:14 PM   #1
Unhappy
Problem with GMT090-3 gas furnace
I have a gas furnace GMT090-3 80%. When I turn the heating on there is the regular motor sound but no ignition. The LED in the board flashes 3 times which is for "pressure switch failure to close" and tells me to check "venter pressure switch venter blockage". I have checked the hose between inducer motor and pressure switch and looks good, also the vent hose looks good. The inductor motor is not turning on. Is the inductor motor defective? If yes, how can I check for it? Or may it be the board that is defective? Any other idea on what can be wrong having these 3 flashes in the LED? Thanks
amx13 is offline   Reply With Quote
Old 04-29-2010, 05:44 PM   #2
An old Tradesmen
Rewards Points: 6,516
Check to see if its getting voltage.
Tags
gas furnace problem , goodman , inductor motor , pressure switch
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 09:04 AM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 01:01 AM
problem with Furnace staying on. rdavis HVAC 4 12-01-2009 10:19 PM
Help - Problem with Oil Fired Forced Air Furnace JohnF HVAC 13 01-31-2009 10:04 PM
