Problem With Gas Cock On Furnace - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 07:45 PM   #16
Update. I called a gas guy and he told me that it sounded like I had to much pressure in the line for it to be doing that. He asked what color of regulator I have on the tank and I said the guy gave me a red one. He said that its the wrong regulator and I should have a grey one. So now I hope I didnt screw up my valve on the furnace. He said it should be ok once I get the correct regulator.
oilerman is offline   Reply With Quote
Old 02-28-2012, 07:53 PM   #17
An old Tradesmen
Rewards Points: 7,802
If moe then 1/2PSIG(14 inches of water column) was applied to the valve, its done for.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (02-28-2012)
Old 02-28-2012, 08:04 PM   #18
Rewards Points: 582
do yourself a real favor....no disrespect...please call in a pro .we would like to have you around for awhile...to many things for the average h.o to consider...ben
Old 02-28-2012, 08:22 PM   #19
For something that seemed so simple sure turned into a headache. I will try the correct regulator and soap the valve to see if it leaks.... if its hooped I will just get it done up by a pro.
The Following User Says Thank You to oilerman For This Useful Post:
Old 02-28-2012, 08:35 PM   #20
Rewards Points: 582
read post #17 if to much pressure was applied to valve its trash....becareful..use good judgement...ben
Old 02-28-2012, 08:45 PM   #21
how
Rewards Points: 1,104
The problem with a valve that's been overgassed is not just gas leaking through the seals so you smell it.. It's that the valve can be internally damaged and later over overgas your heater. I've seen it happen.
The damage is not always detectable or immediately noticeable until the results reveal themselves as a health issue to yourself or the furnace.
Do you really want to be living in a small space with this potential?
I love the DIY attitude but this is one best left to a pro to check out the exchanger( to see if the valve change is worth the investment) and to change the valve.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
Old 03-02-2012, 01:01 AM   #22
Well another update... I had a gas guy come out to check out the valve on the furnace. I installed the correct regulator... And it was the one I wanted in the first place..... Anyways he says that these style of valves can take a lot more pressure than reccomended and still work fine. We fired the furnace up and everything is working fine. He had his gauges and all on it and everything checked out ok.
Old 03-02-2012, 06:45 AM   #23
Rewards Points: 582
thanks for the up date..not sure about valve handling more pressure never knew that..oh well glad to hear its working fine.....
Old 03-02-2012, 12:47 PM   #24
An old Tradesmen
Its not true. Its a lazy guys excuse for getting out of changing a valve.
ben's plumbing (03-02-2012)
Old 03-02-2012, 01:04 PM   #25
Hvac Pro
yuri's Avatar
Rewards Points: 116
Ignorance is bliss and the tech is not the one that will die in the fire. Most people don't survive trailer fires either.
The Following User Says Thank You to yuri For This Useful Post:
Old 03-02-2012, 02:44 PM   #26
OH no...!
Somebody tell HeyBob...or not...since ignorance is bliss
hvaclover is offline   Reply With Quote
Old 03-03-2012, 06:21 AM   #27
Rewards Points: 1,216
People are under the impression that if something has malfunctioned once and now it works OK is false.
If it fails once it will fail again and when you lease expect it, IE; Holidays , Weekends, Parties, While your away, When your broke, whatever.
Like stuck compressors once they stick throw them out because they will stick again, guaranteed.
COLDIRON is offline   Reply With Quote
The Following 2 Users Say Thank You to COLDIRON For This Useful Post:
ben's plumbing (03-03-2012), yuri (03-03-2012)
Old 03-03-2012, 07:31 AM   #28
Hvac Pro
yuri's Avatar
Rewards Points: 116
People believe what they WANT to believe . Not whats true or safe but anything to save a buck $.
The Following 2 Users Say Thank You to yuri For This Useful Post:
ben's plumbing (03-03-2012), COLDIRON (03-03-2012)
Old 03-03-2012, 07:49 AM   #29
Missouri Bound's Avatar
Here in MO and back in Illinois the LP provider did ALL the conversions for heaters and appliances. That's their job. They hae the qualifications to do it properly and the resources.
Do you want it your way or the right way?
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 08:04 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 12:01 AM
