Problem With Gas Cock On Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 10:14 PM   #1
Problem with gas cock on furnace
Well here is my story... I bought a 91 mobile home and the it has a coleman furnace running off natural gas. I dont have my natural gas put in yet so I converted it over to LP as per the instructions. It was pretty easy. I proceeded to light the pilot tonight and when I turned the gas cock to the pilot postions and pushed down ( this is while I had a long match in the hole) the propane gas started to come out from the gas cock. Scared the crap outta me and the smell was strong. I shut everything off and turned the power off. Do I have to replace the whole valve assembly?
oilerman is offline   Reply With Quote
Old 02-27-2012, 10:21 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Depending on the gas cock I would say yes. There are some valves that have a nut on the bottom of the valve that you can tighten while holding the top of the valve.
But what is 7 bucks compared to an explosion.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-27-2012, 10:33 PM   #3
Any reason why they would do that... this was like pushing down on the valve stem of a tire when I pushed down to light the pilot. And ony $7??? I was thinking like 150 bucks?
Old 02-27-2012, 10:35 PM   #4
Rewards Points: 12,876
One of the dozen or so reasons I'd never suggest a DIY work on anything to do with gas.
Please call the gas company and have them take care of it.
Old 02-27-2012, 10:37 PM   #5
Rewards Points: 560
Ok we are not talking about the same thing.
Gas cock = A valve used to turn on/off gas manually by you
Gas Valve = A valve used to control fuel gas into a furnace. Controlled by electronic or switches within the furnace
So, your gas valve leaks when you try to lite the pilot..correct?
Sounds as though when you converted the valve to LP you didn't get the regulator plate back on correctly. If you replaced the spring/
Old 02-27-2012, 10:38 PM   #6
how
Rewards Points: 1,070
So you converted a valve set up from NG to LG with a spring change kit for the higher pressure for the valve?
I take it you also changed the orifices in the furnace manifold as well?
The valve is not supposed to vent like that and if you soaped it you'd probably find the gas coming out from around the depressed handle.
Yes! Get the valve assy changed. Leaking propane in a confined space is deadly.
I'd also like to hear what you did to switch that unit over to propane?
how is offline   Reply With Quote
Old 02-27-2012, 10:40 PM   #7
Rewards Points: 560
Please gas the gas company and have them take care of it.
Gas the Gas Company.....Now that's down right funny
Old 02-27-2012, 10:40 PM   #8
Yes you are correct.... I am talking about the gas valve... sorry. Goes from off to pilot then to on.
Old 02-27-2012, 10:48 PM   #9
Yes! Get the valve assy changed. Leaking propane in a confined space is a deadly.
No spring was in the kit. And it didnt mention anything about a spring on the directions the on the furnace. Without looking at the diagram on the furnace right now I flipped over the little brass fitting with the plastic cap on top of it to read LP as per instructions... then I pulled the manifold out and changed the orifce out to the .98 LP one. Put it back together and that was it. All the parts where located in the little pouch hanging on the valve assembly.
Old 02-28-2012, 05:24 AM   #10
An old Tradesmen
Rewards Points: 6,136
That is the typical set up for an LP conversion on those Coleman MH furnaces. Sounds like you have a valve with a bad seal in it. Gas valve needs replaced.
Old 02-28-2012, 12:20 PM   #11
Thanks. Hope i can find one!
Old 02-28-2012, 12:23 PM   #12
Thats the reason I converted it to propane because the gas wont be put in tell fall.
Old 02-28-2012, 01:09 PM   #13
Hvac Pro
yuri's Avatar
Rewards Points: 1,144
coleman got taken over by York/Johnson controls but at 22 yrs they may not have a complete paper trail for the parts. try americanhvacparts.com. beware that mobile home units are special and you may have to get it from a RV dealer or mobile home manufacturers service store which specializes in trailer furnace parts. can you get by till fall as you will then have to convert it to gas and make sure the valve is backwards convertible. sounds like a lot of hassle to me. at 22 yrs old the heat exchanger is probably in poor condition so I would think about a new furnace instead. miller/nordyne is the most popular and easy to get parts for.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (02-28-2012)
Old 02-28-2012, 02:39 PM   #14
Took me a minute...
hvac5646 is offline   Reply With Quote
Old 02-28-2012, 06:06 PM   #15
Pull that burner assembly and check the heat exchanger before buying a new gas valve. I work on very few of them but have not seen one last more than 15 years before cracking.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 09:04 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 09:18 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 01:01 AM
