After having the chance to do more research and disassemble and inspect the wiring I know the following additional information...
My heating is controlled by a single pole breaker in my panel, 15A.
My thermostat has 2 line wires and two load wires (i.e. double pole). Both line wires are wire nutted to THREE black wires coming from the wall.
One load wire is nutted to THREE red wires leading into the wall. I've confirmed the three red wires is the heater/pump load.
The other load wire is nutted to a single black wire. This is the fan load.
By switching the load wires I was able to get the desired behavior that the heater/pump does not start up until the room temp is below the tstat temp. This means the fan is always getting power when the tstat is on, but the fan unit has an aquastat that waits until the water reaches a certain temperature (140F I think) before the fan spins. So this has solved my immediate energy/gas bill problem.
Now to the issue of selecting a replacement thermostat. It would seem to me I could use any 120V double pole thermostat since that is essentially what I have now. My question is, if I circumvented the switch between the fan load and the line by wiring the fan load directly to the line wire (i.e. replace the "line" wire from the tstat used for the fan with the actual fan load wire from the wall) and then used a single pole thermostat to switch the heater/pump load would I encounter any problems (other than the fan always being on)? Would this violate any code?
Hoping someone can offer some advice here, thanks...
