Problem Changing Filter - HVAC - DIY Chatroom Home Improvement Forum
Old 07-20-2006, 01:21 PM   #1
Doobie in Charlotte
Unhappy
One of our furnace and air handler units is located in the crawl space of our house. It is very difficult at our age to reach the unit and change the air filter every 90 days.
A friend of ours in the HVAC business said that if we remove the air filter from the air handler, we can install a filter on the return vent which is located inside the house. Is this an appropriate solution to our problem?
Thanks for your interest.
Doobie (newbee) in Charlotte
Doobie is offline   Reply With Quote
Old 07-20-2006, 02:43 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Yes. As long as there is a filter in the return before the air handler somewhere. All four of mine are inside my house.
They are the kind that you can backwash clean with a water hose, and I do it faithfully every first of the month.
If I were you, I would check/change them monthly for more energy efficiency.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Changing filter in Whirlpool whole house water filter farnamct Plumbing 7 12-20-2012 09:11 PM
Faucet options for undercounter water filter mdr25 Plumbing 4 03-02-2007 04:56 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
Water Delivery Problem amadis Appliances 6 12-20-2006 10:22 PM
