Problem With Carrier 58MXA Furnace...everything Works, Furnace Won't Come On... - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 01:05 PM   #1
Problem with Carrier 58MXA furnace...everything works, furnace won't come on...
Hi, and thanks for reading. My furnace stopped working last night. As mentioned it the title, everything seems to be working. I jumped the COM terminal to the test terminal and ran a component test. Surface ignitor came on, blowers came on, the test ran fine. I have no flashing error code currently. I have a Honeywell digital thermostat and I can hear the call for heat going through to the furnace. It goes from silent to a low hum when a call for heat is initiated. However, once the call for heat goes through, nothing happens, and the hum persists (I believe the hum is normal?). This just started last night, and I've been reading about resetting the limit switch and flame rollout switch. If no one has a suggestion on what could be wrong, could you at least point out where the flame rollout switch and limit switch is located and how to reset them manually. I can't find anything through google(images) and nothing is listed in my manual.
Thanks again for reading and much appreciation for any suggestions.
~Chipley
Chipley is offline   Reply With Quote
Old 01-31-2010, 05:04 PM   #2
An old Tradesmen
Rewards Points: 6,870
Did you try jumping R to W.
If it works after you do that. Its your stat or stat wires.
carrier 58mvp ingnitor part #/ignition problem GEAF HVAC 8 01-02-2011 04:00 PM
Furnace only works with door off CWinGA HVAC 3 12-05-2009 04:36 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Carrier Furnace Problem Boats1183 HVAC 1 11-11-2008 06:41 PM
Carrier 58MXA pressure problem c5pilot HVAC 3 02-22-2008 07:32 PM
