Old 02-07-2008, 08:38 AM   #1
Default Problem with Burnham Oil Furnace short cycling
Hi
My furnace keeps short cycling at 15 or 30 second intervals all night. It is noisy and is probably consuming a lot of oil. The hot water and heat is fine but the short cycling is driving me mad. I have replaced thermostates, cleaned it's "eye" and adjusted high and low temps on the furnace itself. Oh, moved "differentials". Can someone help me solve this problem? I just don't want to buy and install a new furnace.
Cathy
Catherine M Brown is offline   Reply With Quote
Old 02-07-2008, 09:16 AM   #2
Hi Cathy, have a look here - http://www.nachi.org/forum/showthread.php?t=11747
PAULIE555 is offline   Reply With Quote
Old 02-07-2008, 05:19 PM   #3
Mainah's Avatar
what is your hi/lo limit set at? what the differential set at?
do you have zone valves?
Mainah is offline   Reply With Quote
Old 02-13-2008, 09:42 AM   #4
Hi Mainah
Thank you for replying and your time.
High 190 Low 160 Diff. 15. We have 2 zones and tried swaping out the thermostates. That did not work. Replaced something called an aquastat. That did not work. I turn the heat down very low at night so it will not come on and keep us awake. Then in the morning, I turn it up. The house heats nicely, but when it reaches temp the short cycling starts. The thermostat down stairs is on 55. This is an oil furnace. Everyone seems to be talking about gas furnaces. Help! Again, thank you for taking the time to ask questions. Cathy
Old 02-13-2008, 04:28 PM   #5
Umm...2 zones and replaced an aquastat...not a furnace but a boiler...do you see a gauge reading the water temp?.....the bottom reading is your water pressure....approx. 20lbs...???...do you have bleed valves you can open to let air out...to see if it is low on water???..water supply valve to boiler MUST remain open for automatic replenishment.... some boilers have a low water shutdown!!!!!
econoline is offline   Reply With Quote
Old 02-13-2008, 04:36 PM   #6
Custom Cabinet Maker
It will be cheaper and faster in the long run just to get a serviceman in there. All you are doing is throwing money at an unknown problem and hoping you trip over it. Am NOT being mean just honest.
skymaster is offline   Reply With Quote
Old 02-13-2008, 06:35 PM   #7
Mainah's Avatar
do you have zone valves??
it sounds like it could be the end switch is sticking when it's satisfied for heat
Old 02-14-2008, 09:56 AM   #8
Default Thank you again for replying, Mainah
Hi
We will look at it. We had a service guy out but he charged us $115, cleaned it, and could not solve the problem. I have a cousin in the family that has a business in this field, and he is at a loss for ideas. The chat room people all seem to be talking about gas furnaces with this problem. We are just odd, I guess.
Cathy
Old 02-14-2008, 10:00 AM   #9
Default Already did this
Hi Skymaster,
We did this in step one. The fellow came and cleaned the furnace. The problem remains and I already paid the $115 bill. We are so tired from laying in bed listening to the furnace turn on every 15 seconds wasting fuel that I am ready to replace it!
Thanks for taking the time for the advice.
I just sign off as sleepless in Providence.
Cathy
Old 02-14-2008, 10:02 AM   #10
Default We will try this tonight
Thanks, Econoline
We will try this tonight and let you know what we find. I appreciate your time.
Cathy
Old 02-14-2008, 12:28 PM   #11
In way over my head.
Clutchcargo's Avatar
Try unhooking the thermostat lines at the boiler controls. There may be a partial short in that line someplace causing it to arc. Just a thought.
GL
Edit, no that's not it. Otherwise that behavior would occur even when you turn the thermostat down. If the boiler doesn't cycle on it's way up and doesn't cycle on it's way down, it has to be something the thermostat is doing. You need to determine if the call for heat is also intermittent.
What type of heating system is this? ... baseboard, hydro-air, radiant, steam?
We have determined it's a boiler and not a furnace, correct?
Is it 15-30 seconds on/15-30 seconds off Or is it 30 seconds on/ a few minutes off?
Could you describe exactly what it's doing?
You'll never be sorry you bought the best.
Clutchcargo is offline   Reply With Quote
Old 01-29-2009, 12:32 PM   #12
Default 15-30 second cycle
My oil burner would short cycle like that because the safety flame photo eye was damaged. No reading from the photo-eye system shuts down.
smmcfarland2 is offline   Reply With Quote
Old 01-29-2009, 12:39 PM   #13
An old Tradesmen
If the flame safety shuts it down, thats not short cyclng.
Brown.
What brand zone vavles do you have.
As someone else said, it sounds like one of them is causing the short cycles.
And if it is.
Then you would have the same short cycling with a gas boiler.
Old 01-29-2009, 12:58 PM   #14
Catherine: OK Here is IMHO your easiest bet. Burnham is located in PA I think Lancaster, anyway they have an 800 number and they are some of the best folks you can talk to. They will help ya.
Also go to www.heatinghelp.com greatest heating website out there, Dan Hollihan super bestest expert. First call Burnham, second go to Dan's site and post your problem, willing to bet your problem is solved within 72 hrs.
Jack
More On This Topic
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Hi, this is Cable on behalf of Expert Village. In this clip I'm going to talk about some character designs considerations that you should think about before you start to work on your first walk cycle. Because animation is all about drawing the same thing... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Everyone can benefit from using less energy in their homes. You save money each month on your power bill, plus you have the happy knowledge that you are helping the environment by making your home more energy efficient. If everyone did a few energy... Read More »
Heil Furnace Burner Problem timothyr HVAC 65 10-26-2009 05:49 PM
New High Efficiency Furnace Problem Buster 567 HVAC 3 12-07-2008 03:05 PM
oil furnace problem Dave80 HVAC 1 01-24-2008 09:53 AM
Problem with Rheem Criterion Furnace sweetsue777 HVAC 1 01-22-2008 10:38 PM
furnace problem captjack HVAC 8 11-23-2007 01:15 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
