Problem Blowing Out Low Water Cut Off - Lots Of Oil Discharged - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 11:13 AM   #16
Rewards Points: 610
OH MIke..suggest you read the Peerless web site..a residential steam boiler system is designed to re use the steam..after it has condensed and runs back to the boiler ..hence no make up and should not have excess sludge ..even if on hard water ..it does have to be monitored for water losses though..did you ever consider that the homeowner you were referring to was also blowing down too frequently? thereby creating thew problem.
BTW Peerless is against automatic feed water in domestic systems for that reason alone..therefore if there are water losses the boiler will require attendance and alert the home owner there is a problem. I reiterate..no requirement for make up water..= very minor sludge/scale..excessive blow downs create problems..Common practice for maintenance would be to checxk LWCO with short blow down..once a month ..to make sure the burner shuts off then drain boiler just below LWCO yearly disassemble and clean as required .. Read my other comments..too much mblowdown..= too much sludge/scale
techpappy is offline   Reply With Quote
Old 01-03-2013, 12:08 PM   #17
DIY staff
Rewards Points: 7,174
Techpappy--that was in a three story story commercial building---perhaps I should not have added my 2 cents---I am not a boiler man.
Old 01-03-2013, 12:47 PM   #18
Rewards Points: 610
Oh Mike..that makes more sense commercial heating usually employ steam traps to return the water to a condensate return tank which then pumps the water back into the boilewr through a level control i.e. boiler pump control which is alsmost identical to a LWCO but uses open set of contacts which close when the water inthe boiler is approaching Low Water conditiions thereby refilling the boiler to normal. Quite often, if not maintained properly, the steam traps allow water/steam that is too hot, back to the condensate tank where it evaporates into the room or out to atmosphere via vent pipe..this also causes too much make up resulting in excess solids thus requiring more cleaning and blow downs Not Good
Process steam systems normally lose a lot of steam/water therefore require regular blow downs and chemical additives to treat the water to help keep the solids in suspension so they are purged with the blow downs.
Old 01-03-2013, 01:03 PM   #19
Rewards Points: 610
Also, as per Been There's remarks..could have some oil residue from original installation..e.g., oil from threads on piping..Cleaning with caustic, OR other chemical solution as recommended by water treatment company, as described will rid you of the oils as well. May have to repeat cleaning a few times as residues will carry over from affected system pipng.
Repeated and often blow downs from boiler drain and LWCO are recommended during the cleaning process to get rid of the contaminants.
If you call a commercial water treatment company I'm sure they will be happy to advise you further. You do not have a very large system so, shouldn't take more than a day to clean adequately.
NOTE If you can remove the drain valve after cleaning do so and look inside with a flash light ..you should be able to see nice clean heating surfaces inside. If plugged up with sludge try to remove as much as possible. If there are clean out pipes with caps you can remove the caps but, if they just plugs then attempting to remove them would likely crack the sections so, leave them alone. That's been my experience anyway,,even after heating with torches.
Please let us know how you make out.
Old 01-03-2013, 03:05 PM   #20
LBA
Thanks for all your replies. I'll contact a vendor recommended by Peerless and I'll update you once we have it serviced. Thanks for all your input. It;'s been helpful!
LBA is offline   Reply With Quote
Old 01-03-2013, 05:20 PM   #21
An old Tradesmen
Rewards Points: 7,816
Originally Posted by techpappy View Post
STOP blowing down..period..Only if you see water bouncing in guage glass or if the boiler shuts down intermittently due to low water then restarts after it has been off awhile then you may have to add a little water into the system and if the conditiond persist you will have to have the boiler chemically cleaned.
The LWCO is a safety device that can't work if its loaded up with sediment. It must be blown down on a regular basis in order to keep it clear of sediment that can prevent the float from moving down and opening the safety switch.
I have changed out boilers that cracked from dry firing due to the LWCO not being blown down on a regular basis. Peerless, Weil Mclain, Burnham and others will inspect the cracked boiler to see if it was dry fired and void warranty on it.
The Following User Says Thank You to beenthere For This Useful Post:
oh'mike (01-04-2013)
Old 01-04-2013, 02:25 PM   #22
Rewards Points: 610
OK let's go back to basics. New boiler/system installed..do initial boil out of boiler to rid of contaminants...refill with water...water has X amount of contaminants that will precipitate out of the water once it reaches boiling point and produces steam..the X amount of contaminates is very low BUT, if you blow down, then you have to replace the water with new water which adds more contaminants..you are much better off reducing any blow downs ..just test LWCO.. monthly and just drain minimum amount of water from boiler annually...just below LWCO..disassemble and clean..so, some blow down IS recommended however, excessive blow down creates more impurities/sediments and premature failure of the boiler....in this case I am talking about a closed steam system...too much blow down = too much sediment. I was just frustrated by the excessive blow downs being recommended but, I did submit proper procedures including some blow downs. I too have seen boilers totally plugged with scale but, they were commercial applications where all the steam wast to process. That is totally different I also said to drain boiler to check for sediment build up in bottom but, if I had it from new..only every 2 years. Actually I wouldn't have a steam system. Too much maintenance and lack of control. Convedrt system to hot water if possible. Much better. But, I know...not very practical.
Old 01-04-2013, 03:46 PM   #23
An old Tradesmen
Both single and 2 pipe steam systems have vents. They let air out and they let air in. When they let air in, it causes some minor oxidation on the boiler and the pipes. So new impurities are added to the boiler from normal use. Also, some moisture vapor goes out every heating cycle as the vent vents the air out of the system. A small amount, but it eventually has to be made up with fresh water. A monthly LWCO blow down will never hurt a steam boiler.
Draining sludge off the bottom of the boiler once every 2 years is more then enough for any residential steam boiler.
many new steam boilers are now installed using electronic LWCOs. So monthly blow down is not needed on them. But the sensor should be cleaned every year.
techpappy (01-11-2013)
Old 01-11-2013, 04:23 PM   #24
Rewards Points: 610
Thanks Beenthere..The main point I was trying to make all along was that blowing down too often will cause excessive sludge build up. When I said stop bllowing down I meant that the OP was really over doing it. However, if you have a boiler/system that already has a lot of sludge/oils etc. then, a total boil out and flushing will be required before you can revert to "normal" operation and maintenance procedures. Thanks again. Techpappy
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 07:45 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
