Problem With 50+ Yr Old Oil Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 08:13 PM   #1
problem with 50+ yr old oil furnace
Have a 1960 Preston oil furnace which is having problems.. it injects oil and ignites but won't stay lit.. I ran out of oil, so I put in 25l of pump diesel until my delivery showed up.. so it ran fine with pump diesel... Took about a min to start.. once I got the oil delivered is when problems started.. here is a video of what the unit is doing..
https://www.youtube.com/watch?v=oZZm...e_gdata_player
I have bled the lines, cleaned out the inline filter and pump filter, I have cleaned the injection tube (not sure what its called) but I replaced the brass leads on it that connect to the transformer as one had a crack half way thru at the 90 bend and replaced the nozzle. I have bled about 1.5gals so far.. I assume that would be enough to get any air out of lines. With the bleeder nut removed to pump starts and runs.. seems to have pressure as it shot 6+ft when I didn't have the plastic bleed tube lined up right.. I also cleaned and tested the CAD sensor and it reads 43 Ohms with led flash light pointed at it and increase as the light is pulled away all the way to infinate when dark as it should..
Any help and or idea would be greatly appreciated.. It will run like shown for about 5 mins until the overload on the motor trips from it getting hot..
Thanks!
spikie is offline   Reply With Quote
Old 01-23-2013, 10:48 PM   #2
An old Tradesmen
Rewards Points: 6,132
Limit, burner motor or primary control.
Old 01-24-2013, 06:11 AM   #3
is that the new pulse technology oil furnace
hvac5646 is offline   Reply With Quote
Old 01-24-2013, 08:49 AM   #4
Rewards Points: 6,652
Fifty years old, time to replace with a newer higher efficient unit.
Old 01-25-2013, 12:48 AM   #5
Same advise here.
Why put more money/headache on something this old.
Finding someone who is experience on this unit is either retired or dead.
Mr.HVAC is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Gas Furnace Hiccups hugocraft HVAC 2 12-22-2012 07:50 AM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 09:18 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 01:01 AM
