Problem With A 2005 Miller #CMF80 Oil Furnance - HVAC - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 12:20 PM   #1
Problem with a 2005 Miller #CMF80 oil furnance
We have this installed in our cabin in Michigan 2005 it was installed and we replaced an older Moncrief and put in a new oil tank also the problem is when we leave we turn the thermostat down to 55-60 and when we return to the cabin after a week or 2 the cabin is cold and the thermo stat will not fire the furnance we then hit th reset button and we are good we have had the tech up several times 10-15 oveer the past 7 years and he keeps changing the nozzle checks out the fuel checks the eye and it acts the same any ideas why or what we can do
Thanks Mike
Maddog2020 is offline   Reply With Quote
Old 03-02-2013, 01:24 PM   #2
Experienced HVAC Tech
HVAC1000's Avatar
do you leave the power to the cabin on when you leave?
HVAC1000 is offline   Reply With Quote
Old 03-02-2013, 05:38 PM   #3
An old Tradesmen
Rewards Points: 6,582
Electrodes may be too far apart. possible dead spot in the motor's start windings.
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
miller furnace problem cometcyclone HVAC 1 02-08-2007 08:27 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 03:04 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
Luxaire probane furnance problem jlyle HVAC 4 12-14-2006 12:10 PM
