Pro Th8320 - HVAC - DIY Chatroom Home Improvement Forum
Old 01-27-2010, 12:54 PM   #1
Pro th8320
How many wiers do you need to operate 2heat 1cool gas backup and outside sensor. john
spankyjc is offline   Reply With Quote
Old 01-27-2010, 04:03 PM   #2
An old Tradesmen
Rewards Points: 6,108
1 bundle of min 6 wire. And 1 bundle of min 2 wire.
Old 01-27-2010, 04:25 PM   #3
pro th8320
thanks . Iam hooking up thermostat to heat pump with gas back up. With outside sensor. got 5 wires out of heat pump wiring digram shows you do not need comm wire? an it shows a L terminal for equiment monitor?
Old 01-27-2010, 05:08 PM   #4
An old Tradesmen
If you want to use L, you can, its optional.
It can be operated by batteries only if you want.
1 wire for rh and rc
1 wire for y
1 wire for W/O/B
1 wire for W2
1 wire for g
Optional in same bundle.
1 wire for c
1 wire for L
Outdoor sensor should be ran as a separate wire bundle.
So an 18-2 can be used. i usually run an 18-3 for it.
The IAQ*YTH9421) is a better stat(can not be operated by batteries though). The EIM mounts at the furnace. uses the same number of wire connections. but only needs 3 wires from the EIM to the thermostat. And allows better control of dual fuel systems.
Old 01-28-2010, 10:19 AM   #5
1 wire for y
1 wire for W/O/B
1 wire for W2
1 wire for g
1 wire for c
1 wire for L
still have problem with wiring can you help spanky
Old 01-28-2010, 10:32 AM   #6
pro TH8320
Thanks have one more? Have goodman gmv95 gas furnace . have 8 terminals coming out . do I hook up y g r w1 to conventional side the w2 is for two stage heat . And heat pump has 5 wire r w2 o y c wiych goes to heat pump side? thanks spanky
Old 01-28-2010, 02:38 PM   #7
An old Tradesmen
All wires connect using the heat pump designations on the stat.
RC and RH of stat should have a factory jumper.
From stat to:
RC/RH to R to furnace and heat pump.
Y1 to Y of furnace and heat pump.
G to G of furnace only.
W/O/B to O of furnace and heat pump.
W2 to From stat to W of furnace and heat pump.
C to C of furnace and heat pump.
S1 to one wire of outdoor sensor.
S2 to other wire of outdoor sensor.
Old 01-28-2010, 06:20 PM   #8
That's a 2 stage gas furnace right? 2H 1C the right stat for that with a heat pump?
Old 01-28-2010, 09:47 PM   #9
An old Tradesmen
Isn't that the furnace that can't use a 2 stage heat stat?
Old 01-28-2010, 10:31 PM   #10
No idea. Just trying to do a little learning.
Old 01-28-2010, 10:41 PM   #11
spanky back again yes it is two stage LP gas furnace. With singel stage heat pump,
Old 01-28-2010, 10:45 PM   #12
An old Tradesmen
I'm not sure on that model.
The GMH can't use a 2 stage. And I don't think the OP's model can either.
The Amana version of either can though.
Now you know why its so confusing.
Old 01-28-2010, 10:45 PM   #13
An old Tradesmen
In the furnace install manual. Does it say it can use a 2 stage heat thermostat?
Old 01-28-2010, 11:09 PM   #14
yes it does. IT can . It can use single stage heat singel cool or two stage heat single stage cool or two stage heat two stage cool
Old 01-28-2010, 11:17 PM   #15
An old Tradesmen
So the furnace has a W1 and a W2 terminal?
Then a better stat for your set then would be a Honeywell IAQ.
The one you have can't control 2 stages of gas aux heat.
The IAQ can.
Help for a locked screen on a Honeywell TH8320 thermostat TanyaMendenhall HVAC 3 06-15-2009 11:05 PM
Wiring a TH8320 Ryan314 HVAC 5 12-19-2008 06:52 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 02:30 PM
