PRO To PRO Question..... - HVAC - Page 5 - DIY Chatroom Home Improvement Forum
Old 10-12-2010, 06:35 PM   #61
Nap, if you go in the field you will find that things differ from one city to another.
You can hang a ruined disconnect if you are servicing a resi ac. If you are replacing a new system as long as you do not run new wire or attempt to make the existing wire longer, you can as an HVAC tech hang a disconnect.
hvaclover is offline   Reply With Quote
Old 10-12-2010, 06:37 PM   #62
HVAC / Plumbing
I use 60a pull out type disconnect at the a/c most of the time. I sometimes use HACR breaker that the unit calls for.
Nap,,,I'm from al
kenmac is offline   Reply With Quote
Old 10-12-2010, 06:43 PM   #63
Originally Posted by HVAC_NW View Post
Saying the bolded part makes you look rather clueless. We have either single phase or three phase. Two phase are very very rare, so it doesn't even warrant being mentioned.
Read this and you will understand what polyphase is
A polyphase system is a means of distributing alternating current electrical power. Polyphase systems have three or more energized electrical conductors carrying alternating currents with a definite time offset between the voltage waves in each conductor. Polyphase systems are particularly useful for transmitting power to electric motors. The most common example is the three-phase .
Old 10-12-2010, 07:02 PM   #64
Originally Posted by nap View Post
by hanging a new disco, are you saying on an already installed circuit such as an R&R situation?
In general, I can find nothing in the state laws that would allow you to do any electrical work. Do you have something that allows the work you claim here?
not trying to argue about it. Sincerely looking for a solid answer. Things like this have often been a point of contention so some sort of authoritative cite would help.
Thanks for asking. Yes the local authority has the say so. Local communities can alter the requirments to suit local needs.
The work is inspected by the mechanical guy if he thinks the disco does not meet requirment he turns it over to the electrical inspector. He'll either have the tech correct the issues or require a sparky to runa new line.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
