Old 02-02-2009, 09:01 PM   #1
Default Primary Limit circuit open
My furnace is running but it isn't pumping out heat. The primary limit circuit open light is blinking. Do I need to call a furnace guy or is this something I can fix myself.
thiesnm is offline   Reply With Quote
Old 02-02-2009, 09:10 PM   #2
An old Tradesmen
Need to find out what it causing it to open.
Hopw are your air filters.
Old 02-02-2009, 09:28 PM   #3
The air filter was in backwards and it is dirty and it is kind of deformed. Like blown out.
Old 02-02-2009, 09:47 PM   #4
An old Tradesmen
That may have been the cause.
When I need to change out a limit, I find the cause, and then after correcting that, and replacing the limit. I check to make sure I was right, and have the caused fixed.
Need to check temp rise after replacinga limit.
Old 02-02-2009, 10:05 PM   #5
What exactly is a limit?
Old 02-02-2009, 10:31 PM   #6
An old Tradesmen
Is this case.
It should be your temp limit.
It got too hot, too many times.
When it gets to X temp, it opens to shut off the burner to protect the furnace and your house.
When it cools, it closes again.
They re a safety device. So they aren't made to cycle the burner all the time. So after opening too many times, they tend to stick open.
Old 02-02-2009, 10:41 PM   #7
so how do you close it?
Old 02-02-2009, 11:49 PM   #8
An old Tradesmen
You don't.
You replace it.
Its now unreliable.
Old 02-03-2009, 09:10 AM   #9
been is right so make sure you find the cause instead of just replacing it. A worst-case scenarios is a cracked heat exchanger.
dac122 is offline   Reply With Quote
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to change a furnace filtger. Before you move your filter, you want to make sure and note the direction of air flow. It should be indicated by an arrow on the filter... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be changing our furnace filter. Now right before winter I always recommend to people to go ahead and change out their old furnace filter with a new one. On this unit our furnace filter... Read More »
Hi this is Shana Bethune and on behalf of Expert Village and I'm going to talk to you about using video filters in final cut pro. One of the common uses for video filters is to correct footage that does not look quiet right. You can adjust the color, you... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip, I'll be installing our dry filter. To ensure proper filtration while vacuuming dust and other dry materials, we need to install this dry filter and that is going to help clean our air. If... Read More »
Comfortmaster RPJ II Open High Limit khalidmo81 HVAC 8 01-28-2009 05:47 PM
Diagnostic Code: Primary Limit Circuit Open arete01 HVAC 2 12-30-2008 09:44 PM
Trane Open High Limit Device mdcheddarhead HVAC 3 03-02-2008 07:43 PM
Lock out due to open limit amortiz HVAC 2 03-05-2007 05:34 PM
Comfortmaker RPJII - 4 flashes - open high limit switch nisad HVAC 7 12-08-2006 01:33 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
