Originally Posted by tk03
Sizing steam radiators follow link below.
http://www.comfort-calc.net/tech_are...tm#SteamBoiler
than choose sizing steam radiators.
I agree with Beenthere, there are too many variables for plotting. How do you count for higher efficiencies, quality design, improper as compared to proper sizing, buying power and material?
Your definition is close enough to be correct. The heat goes back from the burner, goes up and comes front in the horizontal flue passes and turns to the rear through other horizontal flue passes.
Thanks for the link.
I assumed furnace output and price were the main things that should correlate well and that are important to the HO.
If I could get data, I'd also plot reliability vs. price.
These two graphs would probably show 90% of what is important to the avg. HO, and they boil down to initial price and cost over time. This is assuming equal comfort levels, and I don't know how to quantify 'comfort'.
If the scatter plot has points all over the place so that it is useless [correlation coefficient less than 0.5] , then I'd look for subcategories to graph, hoping to find a clean straight line that I can use to predict.
In this example
the correlation between the two columns looks lousy on the graph, but it's still rather high, number-wise [0.88].
