Prevent Thermostat From Going Too High - HVAC - DIY Chatroom Home Improvement Forum
Old 11-22-2008, 04:49 PM   #1
Question
Prevent Thermostat from Going Too High
Due to a complicated situation I won't go into, I would like to prevent the heat from going above 68 degrees in our house.
I know this probably isn't possible without a lock box, but I was wondering if I could change the thermometer to read a higher temperature by insulating it more? I don't need the heat to be on. I live in Austin, and trust me, it's not cold.
Anyway to "doctor" the temperature reading? Thanks.
mollybloom is offline   Reply With Quote
Old 11-22-2008, 04:53 PM   #2
Electrical Contractor
kbsparky's Avatar
You are better getting a programmable thermostat, and "locking" it so no one else can tamper with the settings. Some of the newer electronic models have this feature, and you can only "unlock" it with the proper input code.
Old 11-22-2008, 05:38 PM   #3
tk03's Avatar
Rewards Points: 150
or install an accustat which does not let you adjust temperatures. You install a temperature device for the temperature you want. No dials.
tk03 is offline   Reply With Quote
Old 11-22-2008, 05:41 PM   #4
Thank you! That's helpful advice. What, exactly, is an accustat? Is it a new thermostat or is it something I install to my current thermo control box? And if it's the latter, how do I install it?
Old 11-22-2008, 06:34 PM   #5
HvacWiz's Avatar
Rewards Points: 252
I would get a honeywell visonpro t-stat, you can set the stat as you like then go into the internal program and lock it out. http://yourhome.honeywell.com/Consum...hermostats.htm
HvacWiz is offline   Reply With Quote
Old 11-22-2008, 08:03 PM   #6
kbsparky's Avatar
Accustat is probably the best choice for your application, since it is preset with a single value, and cannot be adjusted. You pick the temperature value you want when initially ordering the unit, and that is it.
You would only have the option to switch the system on or off, without any other adjustments being available.
Best used for applications where thermostat tampering can be a problem, or in public buildings, etc.
It would replace any existing thermostat you now are using.
Old 11-23-2008, 12:32 AM   #7
Check this website, http://www.longviewweb.com/psgaccustat.html#s40
pbservano is offline   Reply With Quote
Old 11-23-2008, 05:28 AM   #8
An old Tradesmen
Rewards Points: 7,372
Use a Honeywell Focus, or Vision pro stat.
You can not only lock teh max heat setting. But can also set it to display a temp higher then it actually is.
Accustats are nice. But, if the sensor is removed. It will run your heat no matter what the inside temp is.
Accustat does make a temp limiter that can be installed in teh return duct of a hot air system. That isn't seen by occupants. So they don't know its there.
Tags
thermostat help
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 03:29 AM
High Rise Condo Thermostat Change omanalansan HVAC 8 10-24-2008 02:57 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
